Corrupted blender GUI
    tolkien
    Posts: 584 from 2013/5/29
    I have had two days to can install MorphOS 3.18 and test a few programs.
    All went smooth as always but Blender has problems in its GUI.
    Its like corrupted. Can anyone try it?
    My machine is a G5 with a 9600 Pro 128 mg.
  • »17.05.23 - 17:40
    Posts: 611 from 2003/4/11
    Yea, there is a known regression with text displayed in Blender UI that is visible in the splash window and menus using the TinyGL version that is included in the MorphOS 3.18 update which bigfoot wasn't able to fix in time, mostly because it is very difficult to track down.
  • »17.05.23 - 18:22
    tolkien
    No problem then. Team will catch that bug sooner than later.
  • »17.05.23 - 18:34
