PastePass 1.9 (BETA) released
    Posts: 2593 from 2003/2/24
    This is a complete rewrite using cryptostorage.library (included in the MorphOS ISO) and a major cleanup compared to the versions some people got in 2020/21.
    Only minimal documentation included and will still need some minor cleanups in the GUI and locales but I do want some feedback before making it version 2.0.
    PastePass_1.9
  • »30.10.22 - 13:21
    Posts: 853 from 2007/10/23
    Very good!
    If I try to enter the password for settings the focus is lost after the first letter.
    BTW a tab should be a lf, see PP.png.
  • »31.10.22 - 19:31
    @polluks
    I on the list for "GUI issues".
  • »31.10.22 - 19:40
    Sprocki
    Posts: 132 from 2005/2/23
    I had the same issue a few times. In one case the password was even shown in plain text instead of "asteriskified".
  • »31.10.22 - 21:42
    @polluks
    No idea what you wanna tell me with that png...
    As to the loose of focus, fiddle with pretty much everything touching that string object, it is always happening on 2nd (3rd,4th...) time entering a pass.
    @Sprocki
    I might have found the culprit here will release a fixed version later.
  • »01.11.22 - 08:34
    Just compare the formatting. A few messages are not translated, you know.
    BTW don't use __DATE__ but "date lformat (%d.%m.%y)"
  • »01.11.22 - 16:28
    @polluks
    2 lines of text to clearly say what you wanted to say compared to taking a screenshot and uploading it as a riddle......
    Wrong date format was used as I realized last minute that I had disabled that code when I changed from manual makefile to one maintained by FlowStudio. I have now spent a few minutes to add the defines in FlowStudio and it is now back to proper date string.
    PastePass1.10 can now be downloaded from the same link.
    - fixed date format in about window
    - fixed loss of focus on main password
    - fixed an issue where deleting the database could make it impossible to enter a newly created one
    - reactivated OpenURL support (doubleclick on item)
    - added a few more missing locale strings (still some to go)
  • »04.11.22 - 12:40
    @Kronos
    The password field should be active without clicking.
    Maybe you could show the busy pointer for a second after entering the password.
    The parentheses of the date are mandatory.
    Just solve the "riddle": Your about box has two items, but they are not separated by a line feed. Instead the second one is indented. That's it.
  • »04.11.22 - 21:16
  • ghh
    ghh
    Posts: 60 from 2017/7/15
    One typo in the About window: Yannik -> Yannick.
  • »04.11.22 - 22:44
    PastePass 1.11 can now be downloaded from the same link.
    - changed the default save behavior, it will now only autosave on changing the master PW everything else will pop up a requester if try to quit without manually hitting the "Save" menu before
    - fixed some minor typos and oddities
    - added the missing locale strings
    - added the SimpleCat ".cs" file for translator (hope thats the right one, been a while...)
    Will wait 1-2 weeks for feedback and translation and then rebrand this as the 2.0 release.
  • »12.11.22 - 13:37
    Ups, somehow the archive didn't get updated properly ...
    Try again.
  • »12.11.22 - 14:16
    It's done!
    PastePass 2.0
    Changed since 1.11:
    - added French locale (Papiosaur)
    - database gets set to "changed" on exiting settings so you will get reminded to save before quitting
  • »26.11.22 - 09:37
    PastePass 2.1
    Changed since 2.0:
    - added a basic ARexx/LUA port for retrieving Login/Pass for a given account.
  • »11.10.25 - 13:40
    2 small oversights in the archive:
    - some svn files still present in locale dir
    - double reed an object
    Archive has been updated
    [ Edited by Kronos 12.10.2025 - 04:20 ]
  • »12.10.25 - 01:13
