pegasos 2 and amiga hard disk
    Brumiga
    Posts: 270 from 2004/4/3
    good evening,
    this afternoon i plugged my amiga hard disk into my pegasos 2 as slave on ide 1. on boot appeared my 6 partitions but the 1st, 2nd and 4th seem to have nothing on ambient nor in shell. and on the 3 other partitions many directories were empty. i did a try as master on ide 2 with same results. i upgraded then the firmware successfully but on next boots, as master on ide 2 or slave on ide 1 again the same results. my hard disk uses ffs 40.1 under wb3.1 and the partitions are formated dos5. do i have to convert them to dos1 ? should i "convert" the partitions sfs ?
    Brumiga
    ps : sorry for the 2 previous posts in english in the french section. i did wrong manipulations with the translate option. could it be possible to use this optioon to translate a hole post from a language to another and so post it to the right section ?
  • »18.04.04 - 18:08
