MLDonkey and filesystems
    Hawk
    Posts: 204 from 2003/12/29
    I use mldonkey under Linux. When you start download something, it reserves all the necessary space for that file. But the space it's not actually used. If you do:
    df -h
    you see what I mean. But I tried copying the temp files to a SFS partition, so I could share the download process with the MorphOS client. But then, those files occupied the real space ^^;
    The best thing is using ext2 (ext3) filesystem? whadja think?
    Pegasos II G3@600Mhz (no fan) 512MB RAM (1 slot)
    -- Maxtor 6Y120P0 120GB, 7200 rpm -- ATI Radeon 7500 - (64MB, TV-out)
    -- Minuet Slimline PC case -- MorphOS 1.4.5 + Gentoo
    EFIKA
  • »18.04.04 - 03:32
    GMKai
    Posts: 253 from 2003/4/7
    feel free to port ext to mos :-)
    otherwise you won't be able to use those partitions under mos
  • »18.04.04 - 09:55
