Unpacking .zip files.
    Robert
    Posts: 331 from 2003/5/12
    Can .zip files be unpacked with lha?
    Robert.
  • »17.04.04 - 14:41
    Robert
    OK - thanks for the prompt reply! :pint:
    -EDIT-
    Forgot to ask:
    How does one install/use it?
    Cheers,
    Robert
    Robert.
  • »17.04.04 - 15:21
    liquidbit
    Posts: 408 from 2003/10/12
    Robert, Voodoo-X can! ;-)
  • »17.04.04 - 15:27
  • HAK
    Posts: 225 from 2003/2/24
    Concerning ZipMOS.lha
    When I unpack .zip-files with this tool. All protection bits are deleted (meaning I can't read/write/delete/execute) anything and have to to set them manually afterwards.
    Have I missed a parameter in the help?
    Bye HAK
  • »17.04.04 - 21:30
