Problem with Mixer on x5000
    Mozzerfan
    Posts: 105 from 2016/10/5
    Hi all,
    I have a problem with Mixer on my x5000. I have a soundblaster live and everytime I change the mixer settings and save them, after a reboot of my system, the default settings are back. I doubled checked and the settings are saved, because when I shutdown mixer and start mixer again without a reboot, the new settings are active. Can anybody help me ?
    Thanks.
  • »21.08.22 - 13:58
    Posts: 1386 from 2010/1/6
    You may try delete envarc:sys:xxxmixer.prefs (mixername (xxx) depends on your HW). Reboot and then save your new settings. Hope that will work!
  • »21.08.22 - 17:05
    Mozzerfan
    Thanks AmigaHarry2. But the problem remains. When rebooting the default settings are loaded.
  • »21.08.22 - 17:26
