Posts: 214 from 2011/4/18
hi there,
after many many maaanyy hours, trail and error plus help from this community, I finally managed to get E-UAE running and some WB installed.
There are just two things, I couldnĀ“t figure out:
First, the trackpad of my iBook works fine (including tap-click) on MorphOS side, but the
emulated Amiga does not register clicks on trackpad, just the ones with button are registered.
Is there a way to get tap-click working in Amiga WB as well?
Second things is, the "Apple-Keys" do not register as "Amiga Keys".
In fact, they do nothing at all. CTRL, ALT and Shift are working as expected.
Would be nice to get the Apple/Amiga key connecting running, because I like
to use Keyboard shortcuts-
I am not sure, if NumPad-Keys can be emulated as well (I remember some DPaint Tools, like Perspective for example) are driven by them. On A600 (so no Numpad) there is a workaround, but can't remember what it was ...
Can I somehow emulate a numpad or assign special keys?
Is there a keymap file for E-UAE on MorphOS somewhere, that could be tweaked?
Cheers!
12" ibook G4 1.33Ghz, 1.5GB RAM, ATI 9550 32MB, 16GB SSD, WiFi, BT, ComboDrive
