Posts: 1615 from 2012/11/9
Have you checked if you still have them in the previous version you used?
in
MorphOS-System:Probably-Applications/Wayfarer/Settings>
bookmarks.json <--<< is what you're probably looking for, as the quicklinks are incorporated in there.
