PolyOrganizer questions
    matt3
    Posts: 784 from 2004/2/10
    I'm looking to use PolyOrganizer as my main PIM.
    So far it looks simply awesome and has a rich deep feature set, very impressive.
    Does it have any quirks or bugs that I should know about? Does it have any size limitations for notes under contacts or links ( I tested pasting a huge text file and it wasn't a problem).
    Any other comments from how users feel about it and how long they used it for and how big their database is?
    Thanks for the help.
  • »19.06.22 - 17:06
    tolkien
    Posts: 578 from 2013/5/29
    I dont use that type of programs but I remember Digita Organiser 2 working in MorphOS.
    Its good to have other option.
  • »20.06.22 - 18:23
    matt3
    Thanks Tolkien,
    I tried that but the notes are very limited and doesn't tie contact to appointment. PolyOrganizer is the only PIM on the Amiga that does it all, ontheball does some of it but not nearly as well.
    Tried Timetracker (Not really Y2K compliant and no notes by contact), OnTheBall has robust notes but no linking appointment to contact, Organizer (mentioned above). Tried another one that I can remember right now and it had issues.
    So it is PolyOrganizer or nothing so far...
  • »20.06.22 - 18:49
