Posts: 2202 from 2003/2/24
white wrote:
I added this at the bottom of the user-startup:
SETENV OWB_USER_AGENT "Mozilla / 5.0 (Nintendo WiiU) AppleWebKit / 536.30 (KHTML, like Gecko) NX / 3.0.4.2.13 NintendoBrowser / 4.3.2.11274.US"
BTW. this is a wrong way to set permanent environment variables, it works, but it isn't designed like that. You should use the SAVE option with the
SetEnv command. Then the variable is stored in the env archive directory (ENVARC:) and will be available after reboots.
So, this would make a permanent variable (no need to set it elsewhere in every reboot):
SetEnv OWB_USER_AGENT SAVE "Mozilla / 5.0 (Nintendo WiiU) AppleWebKit / 536.30 (KHTML, like Gecko) NX / 3.0.4.2.13 NintendoBrowser / 4.3.2.11274.US"
