Strato Login
    Posts: 2 from 2021/6/27
    Hello, I want to connect to Strato via Iris. All folders are loaded except INBOX and Spam where there is a synchronization proplem. There I got the following error messages: "Invalid-respnse Recived.invalid response", "Socket_exeption ECONN.RESET connection reset by peer", "illegal-state to accomplish the operation 'Folder not Set'"
    What can I Do?
  • »27.06.21 - 17:57
    Posts: 3337 from 2003/3/5
    Run Iris from shell with 'TRACE' argument like
    sys:applications/iris/iris trace
    and send me the debug log (saved with Logtool).
  • »27.06.21 - 18:57
    The file irislog.txt:
    19:12:25: [weingut-spier@myquix.de] Verbinde ...
    19:12:25: [info@weingut-spier.de] Verbinde ...
    19:12:26: [info@weingut-spier.de] Verbunden.
    19:12:26: [weingut-spier@myquix.de] Verbunden.
    19:12:29: [info@weingut-spier.de] Fehler: invalid_response - Received invalid response.
    19:12:29: Kommando: , Antwort: [^]* 1 FETCH (UID 29104 ENVELOPE ("Fri, 24 Jan 2020 16:54:38 +0100" "Re: Spier ./. Firmenauskunft P.U.R. GmbH" (("Daniel Loschelder" NIL "loschelder" "ll-ip.com")) (("Daniel Loschelder" NIL "loschelder" "ll-ip.com")) (("Daniel Loschelder" NIL "loschelder" "ll-ip.com")) ((NIL NIL "info" "weingut-spier.de")) NIL NIL "<BBB8700D-CDDD-4F2E-9687-07D089F2A116@LL-ip.com>" "<F2C95FA7-A776-405E-80BC-875A64E86989@ll-ip.com>") BODY[HEADER.FIELDS (IMPORTANCE X-PRIORITY)] {2}
    [response]
    19:12:29: [info@weingut-spier.de] Synchronisieren des Ordners INBOX fehlgeschlagen: invalid_response - Received invalid response.!
    19:12:31: [info@weingut-spier.de] Verbunden.
    19:12:32: [info@weingut-spier.de] Ordner Trash synchronisiert ...
    19:12:34: [info@weingut-spier.de] Ordner Sent Items synchronisiert ...
    19:12:35: [info@weingut-spier.de] Fehler: invalid_response - Received invalid response.
    19:12:35: Kommando: , Antwort: [^]* 101 FETCH (UID 246 ENVELOPE ("Mon, 04 May 2020 11:30:35 +0200" "Re: Mathe KW 18 FEHLER" ((NIL NIL "oliver.banyai" "igszell.de")) ((NIL NIL "oliver.banyai" "igszell.de")) ((NIL NIL "oliver.banyai" "igszell.de")) (("info@weingut-spier.de" NIL "info" "weingut-spier.de")) NIL NIL "<20200504111015.Horde.DXPnxWlmNTsrH9YyjoJ-nQ1@webmail.df.eu>" "<20200504113035.Horde.omOQ6d2voJhzh-7CvAI0Og8@webmail.df.eu>") BODY[HEADER.FIELDS (IMPORTANCE X-PRIORITY)] {2}
    [response]
    19:12:35: [info@weingut-spier.de] Synchronisieren des Ordners Spam fehlgeschlagen: invalid_response - Received invalid response.!
    19:12:36: [info@weingut-spier.de] Verbunden.
    19:12:37: [info@weingut-spier.de] Fehler: invalid_response - Received invalid response.
    19:12:37: Kommando: , Antwort: [^]* 1 FETCH (UID 29104 ENVELOPE ("Fri, 24 Jan 2020 16:54:38 +0100" "Re: Spier ./. Firmenauskunft P.U.R. GmbH" (("Daniel Loschelder" NIL "loschelder" "ll-ip.com")) (("Daniel Loschelder" NIL "loschelder" "ll-ip.com")) (("Daniel Loschelder" NIL "loschelder" "ll-ip.com")) ((NIL NIL "info" "weingut-spier.de")) NIL NIL "<BBB8700D-CDDD-4F2E-9687-07D089F2A116@LL-ip.com>" "<F2C95FA7-A776-405E-80BC-875A64E86989@ll-ip.com>") BODY[HEADER.FIELDS (IMPORTANCE X-PRIORITY)] {2}
    [response]
    19:12:37: [info@weingut-spier.de] Synchronisieren des Ordners INBOX fehlgeschlagen: invalid_response - Received invalid response.!
    19:12:38: [info@weingut-spier.de] Verbunden.
    19:12:41: [info@weingut-spier.de] Fehler: invalid_response - Received invalid response.
    19:12:41: Kommando: , Antwort: [^]* 101 FETCH (UID 246 ENVELOPE ("Mon, 04 May 2020 11:30:35 +0200" "Re: Mathe KW 18 FEHLER" ((NIL NIL "oliver.banyai" "igszell.de")) ((NIL NIL "oliver.banyai" "igszell.de")) ((NIL NIL "oliver.banyai" "igszell.de")) (("info@weingut-spier.de" NIL "info" "weingut-spier.de")) NIL NIL "<20200504111015.Horde.DXPnxWlmNTsrH9YyjoJ-nQ1@webmail.df.eu>" "<20200504113035.Horde.omOQ6d2voJhzh-7CvAI0Og8@webmail.df.eu>") BODY[HEADER.FIELDS (IMPORTANCE X-PRIORITY)] {2}
    [response]
    19:12:41: [info@weingut-spier.de] Synchronisieren des Ordners Spam fehlgeschlagen: invalid_response - Received invalid response.!
    19:12:42: [info@weingut-spier.de] Verbunden.
    19:12:43: [info@weingut-spier.de] Fehler: invalid_response - Received invalid response.
    19:12:43: Kommando: , Antwort: [^]* 1 FETCH (UID 29104 ENVELOPE ("Fri, 24 Jan 2020 16:54:38 +0100" "Re: Spier ./. Firmenauskunft P.U.R. GmbH" (("Daniel Loschelder" NIL "loschelder" "ll-ip.com")) (("Daniel Loschelder" NIL "loschelder" "ll-ip.com")) (("Daniel Loschelder" NIL "loschelder" "ll-ip.com")) ((NIL NIL "info" "weingut-spier.de")) NIL NIL "<BBB8700D-CDDD-4F2E-9687-07D089F2A116@LL-ip.com>" "<F2C95FA7-A776-405E-80BC-875A64E86989@ll-ip.com>") BODY[HEADER.FIELDS (IMPORTANCE X-PRIORITY)] {2}
    [response]
    19:12:43: [info@weingut-spier.de] Synchronisieren des Ordners INBOX fehlgeschlagen: invalid_response - Received invalid response.!
    19:12:44: [info@weingut-spier.de] Verbunden.
    19:12:47: [info@weingut-spier.de] Fehler: invalid_response - Received invalid response.
    19:12:47: Kommando: , Antwort: [^]* 101 FETCH (UID 246 ENVELOPE ("Mon, 04 May 2020 11:30:35 +0200" "Re: Mathe KW 18 FEHLER" ((NIL NIL "oliver.banyai" "igszell.de")) ((NIL NIL "oliver.banyai" "igszell.de")) ((NIL NIL "oliver.banyai" "igszell.de")) (("info@weingut-spier.de" NIL "info" "weingut-spier.de")) NIL NIL "<20200504111015.Horde.DXPnxWlmNTsrH9YyjoJ-nQ1@webmail.df.eu>" "<20200504113035.Horde.omOQ6d2voJhzh-7CvAI0Og8@webmail.df.eu>") BODY[HEADER.FIELDS (IMPORTANCE X-PRIORITY)] {2}
    [response]
    19:12:47: [info@weingut-spier.de] Synchronisieren des Ordners Spam fehlgeschlagen: invalid_response - Received invalid response.!
    19:12:48: [info@weingut-spier.de] Verbunden.
    19:12:51: [info@weingut-spier.de] Fehler: invalid_response - Received invalid response.
    19:12:51: Kommando: , Antwort: [^]* 1 FETCH (UID 29104 ENVELOPE ("Fri, 24 Jan 2020 16:54:38 +0100" "Re: Spier ./. Firmenauskunft P.U.R. GmbH" (("Daniel Loschelder" NIL "loschelder" "ll-ip.com")) (("Daniel Loschelder" NIL "loschelder" "ll-ip.com")) (("Daniel Loschelder" NIL "loschelder" "ll-ip.com")) ((NIL NIL "info" "weingut-spier.de")) NIL NIL "<BBB8700D-CDDD-4F2E-9687-07D089F2A116@LL-ip.com>" "<F2C95FA7-A776-405E-80BC-875A64E86989@ll-ip.com>") BODY[HEADER.FIELDS (IMPORTANCE X-PRIORITY)] {2}
    [response]
    19:12:51: [info@weingut-spier.de] Synchronisieren des Ordners INBOX fehlgeschlagen: invalid_response - Received invalid response.!
    19:12:51: [info@weingut-spier.de] Verbunden.
    19:12:54: [info@weingut-spier.de] Fehler: invalid_response - Received invalid response.
    19:12:54: Kommando: , Antwort: [^]* 101 FETCH (UID 246 ENVELOPE ("Mon, 04 May 2020 11:30:35 +0200" "Re: Mathe KW 18 FEHLER" ((NIL NIL "oliver.banyai" "igszell.de")) ((NIL NIL "oliver.banyai" "igszell.de")) ((NIL NIL "oliver.banyai" "igszell.de")) (("info@weingut-spier.de" NIL "info" "weingut-spier.de")) NIL NIL "<20200504111015.Horde.DXPnxWlmNTsrH9YyjoJ-nQ1@webmail.df.eu>" "<20200504113035.Horde.omOQ6d2voJhzh-7CvAI0Og8@webmail.df.eu>") BODY[HEADER.FIELDS (IMPORTANCE X-PRIORITY)] {2}
    [response]
    19:12:54: [info@weingut-spier.de] Synchronisieren des Ordners Spam fehlgeschlagen: invalid_response - Received invalid response.!
    19:12:54: [info@weingut-spier.de] Verbunden.
    19:12:56: [info@weingut-spier.de] Fehler: invalid_response - Received invalid response.
    19:12:56: Kommando: , Antwort: [^]* 1 FETCH (UID 29104 ENVELOPE ("Fri, 24 Jan 2020 16:54:38 +0100" "Re: Spier ./. Firmenauskunft P.U.R. GmbH" (("Daniel Loschelder" NIL "loschelder" "ll-ip.com")) (("Daniel Loschelder" NIL "loschelder" "ll-ip.com")) (("Daniel Loschelder" NIL "loschelder" "ll-ip.com")) ((NIL NIL "info" "weingut-spier.de")) NIL NIL "<BBB8700D-CDDD-4F2E-9687-07D089F2A116@LL-ip.com>" "<F2C95FA7-A776-405E-80BC-875A64E86989@ll-ip.com>") BODY[HEADER.FIELDS (IMPORTANCE X-PRIORITY)] {2}
    [response]
    19:12:56: [info@weingut-spier.de] Synchronisieren des Ordners INBOX fehlgeschlagen: invalid_response - Received invalid response.!
    19:12:59: [info@weingut-spier.de] Verbunden.
    19:13:02: [info@weingut-spier.de] Fehler: invalid_response - Received invalid response.
    19:13:02: Kommando: , Antwort: [^]* 101 FETCH (UID 246 ENVELOPE ("Mon, 04 May 2020 11:30:35 +0200" "Re: Mathe KW 18 FEHLER" ((NIL NIL "oliver.banyai" "igszell.de")) ((NIL NIL "oliver.banyai" "igszell.de")) ((NIL NIL "oliver.banyai" "igszell.de")) (("info@weingut-spier.de" NIL "info" "weingut-spier.de")) NIL NIL "<20200504111015.Horde.DXPnxWlmNTsrH9YyjoJ-nQ1@webmail.df.eu>" "<20200504113035.Horde.omOQ6d2voJhzh-7CvAI0Og8@webmail.df.eu>") BODY[HEADER.FIELDS (IMPORTANCE X-PRIORITY)] {2}
    [response]
    19:13:02: [info@weingut-spier.de] Synchronisieren des Ordners Spam fehlgeschlagen: invalid_response - Received invalid response.!
    19:13:04: [info@weingut-spier.de] Verbunden.
    19:13:07: [info@weingut-spier.de] Fehler: invalid_response - Received invalid response.
    19:13:07: Kommando: , Antwort: [^]* 1 FETCH (UID 29104 ENVELOPE ("Fri, 24 Jan 2020 16:54:38 +0100" "Re: Spier ./. Firmenauskunft P.U.R. GmbH" (("Daniel Loschelder" NIL "loschelder" "ll-ip.com")) (("Daniel Loschelder" NIL "loschelder" "ll-ip.com")) (("Daniel Loschelder" NIL "loschelder" "ll-ip.com")) ((NIL NIL "info" "weingut-spier.de")) NIL NIL "<BBB8700D-CDDD-4F2E-9687-07D089F2A116@LL-ip.com>" "<F2C95FA7-A776-405E-80BC-875A64E86989@ll-ip.com>") BODY[HEADER.FIELDS (IMPORTANCE X-PRIORITY)] {2}
    [response]
    19:13:07: [info@weingut-spier.de] Synchronisieren des Ordners INBOX fehlgeschlagen: invalid_response - Received invalid response.!
    19:13:07: [info@weingut-spier.de] Verbunden.
    19:13:10: [info@weingut-spier.de] Fehler: invalid_response - Received invalid response.
    19:13:10: Kommando: , Antwort: [^]* 101 FETCH (UID 246 ENVELOPE ("Mon, 04 May 2020 11:30:35 +0200" "Re: Mathe KW 18 FEHLER" ((NIL NIL "oliver.banyai" "igszell.de")) ((NIL NIL "oliver.banyai" "igszell.de")) ((NIL NIL "oliver.banyai" "igszell.de")) (("info@weingut-spier.de" NIL "info" "weingut-spier.de")) NIL NIL "<20200504111015.Horde.DXPnxWlmNTsrH9YyjoJ-nQ1@webmail.df.eu>" "<20200504113035.Horde.omOQ6d2voJhzh-7CvAI0Og8@webmail.df.eu>") BODY[HEADER.FIELDS (IMPORTANCE X-PRIORITY)] {2}
    [response]
    19:13:10: [info@weingut-spier.de] Synchronisieren des Ordners Spam fehlgeschlagen: invalid_response - Received invalid response.!
    19:13:11: [info@weingut-spier.de] Verbunden.
    19:13:12: [info@weingut-spier.de] Fehler: invalid_response - Received invalid response.
    19:13:12: Kommando: , Antwort: [^]* 1 FETCH (UID 29104 ENVELOPE ("Fri, 24 Jan 2020 16:54:38 +0100" "Re: Spier ./. Firmenauskunft P.U.R. GmbH" (("Daniel Loschelder" NIL "loschelder" "ll-ip.com")) (("Daniel Loschelder" NIL "loschelder" "ll-ip.com")) (("Daniel Loschelder" NIL "loschelder" "ll-ip.com")) ((NIL NIL "info" "weingut-spier.de")) NIL NIL "<BBB8700D-CDDD-4F2E-9687-07D089F2A116@LL-ip.com>" "<F2C95FA7-A776-405E-80BC-875A64E86989@ll-ip.com>") BODY[HEADER.FIELDS (IMPORTANCE X-PRIORITY)] {2}
    [response]
    19:13:12: [info@weingut-spier.de] Synchronisieren des Ordners INBOX fehlgeschlagen: invalid_response - Received invalid response.!
    19:13:14: [info@weingut-spier.de] Verbunden.
    19:13:18: [info@weingut-spier.de] Fehler: invalid_response - Received invalid response.
    19:13:18: Kommando: , Antwort: [^]* 101 FETCH (UID 246 ENVELOPE ("Mon, 04 May 2020 11:30:35 +0200" "Re: Mathe KW 18 FEHLER" ((NIL NIL "oliver.banyai" "igszell.de")) ((NIL NIL "oliver.banyai" "igszell.de")) ((NIL NIL "oliver.banyai" "igszell.de")) (("info@weingut-spier.de" NIL "info" "weingut-spier.de")) NIL NIL "<20200504111015.Horde.DXPnxWlmNTsrH9YyjoJ-nQ1@webmail.df.eu>" "<20200504113035.Horde.omOQ6d2voJhzh-7CvAI0Og8@webmail.df.eu>") BODY[HEADER.FIELDS (IMPORTANCE X-PRIORITY)] {2}
    [response]
    19:13:18: [info@weingut-spier.de] Synchronisieren des Ordners Spam fehlgeschlagen: invalid_response - Received invalid response.!
    19:13:18: [info@weingut-spier.de] Verbunden.
    19:13:20: [info@weingut-spier.de] Fehler: invalid_response - Received invalid response.
    19:13:20: Kommando: , Antwort: [^]* 1 FETCH (UID 29104 ENVELOPE ("Fri, 24 Jan 2020 16:54:38 +0100" "Re: Spier ./. Firmenauskunft P.U.R. GmbH" (("Daniel Loschelder" NIL "loschelder" "ll-ip.com")) (("Daniel Loschelder" NIL "loschelder" "ll-ip.com")) (("Daniel Loschelder" NIL "loschelder" "ll-ip.com")) ((NIL NIL "info" "weingut-spier.de")) NIL NIL "<BBB8700D-CDDD-4F2E-9687-07D089F2A116@LL-ip.com>" "<F2C95FA7-A776-405E-80BC-875A64E86989@ll-ip.com>") BODY[HEADER.FIELDS (IMPORTANCE X-PRIORITY)] {2}
    [response]
    19:13:20: [info@weingut-spier.de] Synchronisieren des Ordners INBOX fehlgeschlagen: invalid_response - Received invalid response.!
    19:13:21: [info@weingut-spier.de] Verbunden.
    19:13:25: [info@weingut-spier.de] Fehler: invalid_response - Received invalid response.
    19:13:25: Kommando: , Antwort: [^]* 101 FETCH (UID 246 ENVELOPE ("Mon, 04 May 2020 11:30:35 +0200" "Re: Mathe KW 18 FEHLER" ((NIL NIL "oliver.banyai" "igszell.de")) ((NIL NIL "oliver.banyai" "igszell.de")) ((NIL NIL "oliver.banyai" "igszell.de")) (("info@weingut-spier.de" NIL "info" "weingut-spier.de")) NIL NIL "<20200504111015.Horde.DXPnxWlmNTsrH9YyjoJ-nQ1@webmail.df.eu>" "<20200504113035.Horde.omOQ6d2voJhzh-7CvAI0Og8@webmail.df.eu>") BODY[HEADER.FIELDS (IMPORTANCE X-PRIORITY)] {2}
    [response]
    19:13:25: [info@weingut-spier.de] Synchronisieren des Ordners Spam fehlgeschlagen: invalid_response - Received invalid response.!
    19:13:25: [info@weingut-spier.de] Verbunden.
    19:13:28: [info@weingut-spier.de] Fehler: invalid_response - Received invalid response.
    19:13:28: Kommando: , Antwort: [^]* 1 FETCH (UID 29104 ENVELOPE ("Fri, 24 Jan 2020 16:54:38 +0100" "Re: Spier ./. Firmenauskunft P.U.R. GmbH" (("Daniel Loschelder" NIL "loschelder" "ll-ip.com")) (("Daniel Loschelder" NIL "loschelder" "ll-ip.com")) (("Daniel Loschelder" NIL "loschelder" "ll-ip.com")) ((NIL NIL "info" "weingut-spier.de")) NIL NIL "<BBB8700D-CDDD-4F2E-9687-07D089F2A116@LL-ip.com>" "<F2C95FA7-A776-405E-80BC-875A64E86989@ll-ip.com>") BODY[HEADER.FIELDS (IMPORTANCE X-PRIORITY)] {2}
    [response]
    19:13:28: [info@weingut-spier.de] Synchronisieren des Ordners INBOX fehlgeschlagen: invalid_response - Received invalid response.!
    19:13:28: [info@weingut-spier.de] Verbunden.
    19:13:31: [info@weingut-spier.de] Fehler: invalid_response - Received invalid response.
    19:13:31: Kommando: , Antwort: [^]* 101 FETCH (UID 246 ENVELOPE ("Mon, 04 May 2020 11:30:35 +0200" "Re: Mathe KW 18 FEHLER" ((NIL NIL "oliver.banyai" "igszell.de")) ((NIL NIL "oliver.banyai" "igszell.de")) ((NIL NIL "oliver.banyai" "igszell.de")) (("info@weingut-spier.de" NIL "info" "weingut-spier.de")) NIL NIL "<20200504111015.Horde.DXPnxWlmNTsrH9YyjoJ-nQ1@webmail.df.eu>" "<20200504113035.Horde.omOQ6d2voJhzh-7CvAI0Og8@webmail.df.eu>") BODY[HEADER.FIELDS (IMPORTANCE X-PRIORITY)] {2}
    [response]
    19:13:31: [info@weingut-spier.de] Synchronisieren des Ordners Spam fehlgeschlagen: invalid_response - Received invalid response.!
    19:13:32: [info@weingut-spier.de] Verbunden.
    19:13:33: [info@weingut-spier.de] Fehler: invalid_response - Received invalid response.
    19:13:33: Kommando: , Antwort: [^]* 1 FETCH (UID 29104 ENVELOPE ("Fri, 24 Jan 2020 16:54:38 +0100" "Re: Spier ./. Firmenauskunft P.U.R. GmbH" (("Daniel Loschelder" NIL "loschelder" "ll-ip.com")) (("Daniel Loschelder" NIL "loschelder" "ll-ip.com")) (("Daniel Loschelder" NIL "loschelder" "ll-ip.com")) ((NIL NIL "info" "weingut-spier.de")) NIL NIL "<BBB8700D-CDDD-4F2E-9687-07D089F2A116@LL-ip.com>" "<F2C95FA7-A776-405E-80BC-875A64E86989@ll-ip.com>") BODY[HEADER.FIELDS (IMPORTANCE X-PRIORITY)] {2}
    [response]
    19:13:33: [info@weingut-spier.de] Synchronisieren des Ordners INBOX fehlgeschlagen: invalid_response - Received invalid response.!
    19:13:36: [info@weingut-spier.de] Verbunden.
    19:13:39: [info@weingut-spier.de] Fehler: invalid_response - Received invalid response.
    19:13:39: Kommando: , Antwort: [^]* 101 FETCH (UID 246 ENVELOPE ("Mon, 04 May 2020 11:30:35 +0200" "Re: Mathe KW 18 FEHLER" ((NIL NIL "oliver.banyai" "igszell.de")) ((NIL NIL "oliver.banyai" "igszell.de")) ((NIL NIL "oliver.banyai" "igszell.de")) (("info@weingut-spier.de" NIL "info" "weingut-spier.de")) NIL NIL "<20200504111015.Horde.DXPnxWlmNTsrH9YyjoJ-nQ1@webmail.df.eu>" "<20200504113035.Horde.omOQ6d2voJhzh-7CvAI0Og8@webmail.df.eu>") BODY[HEADER.FIELDS (IMPORTANCE X-PRIORITY)] {2}
    [response]
    19:13:39: [info@weingut-spier.de] Synchronisieren des Ordners Spam fehlgeschlagen: invalid_response - Received invalid response.!
    19:13:39: [info@weingut-spier.de] Verbunden.
    19:13:41: [info@weingut-spier.de] Fehler: invalid_response - Received invalid response.
    19:13:41: Kommando: , Antwort: [^]* 1 FETCH (UID 29104 ENVELOPE ("Fri, 24 Jan 2020 16:54:38 +0100" "Re: Spier ./. Firmenauskunft P.U.R. GmbH" (("Daniel Loschelder" NIL "loschelder" "ll-ip.com")) (("Daniel Loschelder" NIL "loschelder" "ll-ip.com")) (("Daniel Loschelder" NIL "loschelder" "ll-ip.com")) ((NIL NIL "info" "weingut-spier.de")) NIL NIL "<BBB8700D-CDDD-4F2E-9687-07D089F2A116@LL-ip.com>" "<F2C95FA7-A776-405E-80BC-875A64E86989@ll-ip.com>") BODY[HEADER.FIELDS (IMPORTANCE X-PRIORITY)] {2}
    [response]
    19:13:41: [info@weingut-spier.de] Synchronisieren des Ordners INBOX fehlgeschlagen: invalid_response - Received invalid response.!
    19:13:42: [info@weingut-spier.de] Verbunden.
    19:13:44: [info@weingut-spier.de] Fehler: invalid_response - Received invalid response.
    19:13:44: Kommando: , Antwort: [^]* 101 FETCH (UID 246 ENVELOPE ("Mon, 04 May 2020 11:30:35 +0200" "Re: Mathe KW 18 FEHLER" ((NIL NIL "oliver.banyai" "igszell.de")) ((NIL NIL "oliver.banyai" "igszell.de")) ((NIL NIL "oliver.banyai" "igszell.de")) (("info@weingut-spier.de" NIL "info" "weingut-spier.de")) NIL NIL "<20200504111015.Horde.DXPnxWlmNTsrH9YyjoJ-nQ1@webmail.df.eu>" "<20200504113035.Horde.omOQ6d2voJhzh-7CvAI0Og8@webmail.df.eu>") BODY[HEADER.FIELDS (IMPORTANCE X-PRIORITY)] {2}
    [response]
    19:13:44: [info@weingut-spier.de] Synchronisieren des Ordners Spam fehlgeschlagen: invalid_response - Received invalid response.!
    19:13:45: [info@weingut-spier.de] Verbunden.
  • »28.06.21 - 16:40
