OWB vs Wayfarer speed
    Posts: 3337 from 2003/3/5
    There will be no private mode. Don't see how that'd help with cookie consent screens.
  • »07.11.20 - 20:53
    Posts: 141 from 2017/8/6
    Give us the tools and we might be able to show.
    I can show a video with the fans running wild but i have no other clue.
    [ Edited by amifrog 07.11.2020 - 22:59 ]
  • »07.11.20 - 20:56
    Posts: 12572 from 2003/5/22
    I guess what was meant is that private browsing mode wouldn't prevent cookie consent screens from appearing.
  • »08.11.20 - 05:54
    Private mode would allow to just click accept instead of going through the painful process and actually deselect all this crap. Of course it will popup every time but to avoid tracking its much easier to allow everything with one click.
    At least thats the idea.🙃
  • »08.11.20 - 10:02
    Intuition
    Posts: 1116 from 2013/5/24
    Et voila!
    http://prebake.eu/
  • »08.11.20 - 10:41
    Posts: 2095 from 2003/6/4
    jacadcaps schrieb:
    Zylesea wrote:
    - Missing option to visit a site regardless of a non trusty certificate.
    Simply click on the trust icon or Show Certificate in the error message.
    Sometimes I wonder if I am just too stupid, but the trust icon is the littleshield icon left to the url string? If I click on that, some information about the certificate gets shown, but there is no option to trust/visit that site. Just the information. Am I overseeing something?
    bild-20a273-1621265566.png.html
  • »17.05.21 - 13:37
    Hard to say. It looks like the code validating the certificate in this window appears to find no issues with it, while the curl backend does (it's not the same code, unfortunately). Otherwise you'd see the error (and buttons) there. Is the intermediate certificate OK? Does this happen every time you try to open this site?
    [ Edited by jacadcaps 18.05.2021 - 20:39 ]
  • »18.05.21 - 16:29
    It's happening since the since a couple of days. And strange enough: It's not happening on my G5 ir Mac mini. Hence the issue must be somewhere with something specific on the Powerbook (network settings should be identical).
    Eventually it's no big deal in regards to usability as google.com works just fine. Thanks fo explaining why sometimes there are no buttons (different code bases).
    I'll look into what downloading wayfarer again on the powerbook will do....
    Edit: reinstalling wayfarer made that issue disappear. Unfortunately I overwrote the old wayfarer drawer completely, hence no way to nail it down.
    [ Editiert durch Zylesea 18.05.2021 - 23:52 ]
  • »18.05.21 - 19:38
    Posts: 2220 from 2003/2/24
    Piru wrote:
    Google is infuriating to debug here since they are so globally distributed the certificate configuration is in a constant flux. That is, I can't reproduce the issue since I'm getting completely different certificates and it works just fine.
    When I visit the site I get "GlobalSign > GTS CA 101 > www.google.de" chain. SSLLabs sees the same: https://www.ssllabs.com/ssltest/analyze.html?d=www.google.de&s=172.217.164.99
    When I visited www.google.de, it worked normally, but if I visit www.google.fi, then I also get the certificate problem where I can't go ahead... this has been a longer issue for me.
  • »19.05.21 - 06:12
