lots o backgrounds
  • Targhan
    Posts: 2833 from 2003/2/7
    Catohagen released a lot of backdrops and replacement boot-pics for morphos - THIS HERE LINK!.
    Since I realize that using dialup can make posting on those individual pictures a slow and painful process, I decided to try a thread in the forums. Personally, I like the boot-pics, but haven't tried to change any yet. have any of you? What do you think of the backgrounds?
    :idea:Targhan
  • »13.04.04 - 20:17
    Posts: 159 from 2003/10/24
    Cool. Two questions. What is the boot picture called and where can I find it?
    --Mithalas
  • »13.04.04 - 20:37
    Posts: 2561 from 2003/2/24
    Another one suffering from invisble-link-syndrome ?
    Just click on "here" in Targhan's post, and than onto one of images in the new windo.
  • »13.04.04 - 21:09
    Black_Eagle
    Posts: 70 from 2003/6/5
    @Mithalas
    If you mean what the boot picture is called in MorphOS it's cgxbootpic.library (I think... not at home, so I can't check spelling) and it should be in LIBS:
    You need a tool that patches the library too.
    Nut in MorphOS you can only see the bootpic for maybe a second so I won't bother changing it =)
    OnyxSoft - Amigans never surrender, they know they can do it better...
  • »14.04.04 - 11:23
    @ Black_Eagle
    Thanks. Since it takes a patch to lib I won't even bother with it.
    --Mithalas
  • »14.04.04 - 13:40
