What do you use for system menu information ?
    Posts: 278 from 2003/3/4
    What is the best integrated, best looking system (CPU / memory / Disk / network) usage ?
    Writing my first post from MorphOS 3.15 and Wayfarer :)
    Thanks !
  • »26.02.21 - 21:57
    Debaser
    Posts: 161 from 2005/7/12
    Does this help? Really all I use and I can double click to get better insight with the CPU monitor screenbar module for instance.
    https://library.morph.zone/Screenbar_Modules
    If you are new to Morphos a look through Morphzone's library can uncover some good tips.
  • »27.02.21 - 12:05
    Posts: 12572 from 2003/5/22
    ...and also if you're just new to MorphOS >3.0 ;-)
  • »27.02.21 - 18:43
    Not really new as I was running very early versions on my Cyberstorm but then it has been 10 years without using it or getting news about it.
    Thanks for the tips. Nice to see so many things that were taking a lot of knowledge / time / settings to be nicely integrated OOTB now.
  • »02.03.21 - 20:08
