Default Icons
    Hawk
    Posts: 204 from 2003/12/29
    Hi, I am trying to change some default icons. Which is the name of the default icon for a CD or a DVD?
    When I insert a CD/DVD I just get the icon of a harddisk... I tried copying the icon of the MorphOS CD to the env-archive directory under different names: def_CD.info, def_CDROM.info, def_DVD.info ...
    How I know the default icon names? Should I install something?
    Bye!
    Pegasos II G3@600Mhz (no fan) 512MB RAM (1 slot)
    -- Maxtor 6Y120P0 120GB, 7200 rpm -- ATI Radeon 7500 - (64MB, TV-out)
    -- Minuet Slimline PC case -- MorphOS 1.4.5 + Gentoo
    EFIKA
  • »11.04.04 - 04:56
    nels664868
    Posts: 117 from 2003/12/28
    Hi Hawk,
    The default Icons stored in 'SYS:Prefs/env-archive/sys'.
    The name format for disks (harddrives,cdroms,zipdrives) is,
    'def_disk.info' for generic disks
    'def_XXXdisk.info' for mounted disks where 'XXX' is the mountlist name (ie. HD0,CD0,CD1,ZIP0)
    So copy your CD icon to 'SYS:Prefs/env-archive/sys'
    and rename it to 'def_CD0disk.info' for the first cd/dvd drive.
    Then your cd icon will show for a cd.
    nels.
    Ask Dr. Stupid,
    Dear Dr. Stupid,
    Why do we have to go to school?
    That's a very good question. It's becuse your parents are
    ALIENS!!! When your at school they shed there human skins and
    breathe drier lint! hahahaha!
  • »11.04.04 - 07:10
    Sphinx_Ra
    Posts: 276 from 2003/3/15
    @nels
    Thx.. did not know this eiter to :-D
    Can i change USB Drawers Icons to ???
    Thx
  • »11.04.04 - 14:32
    Toto
    Posts: 268 from 2003/4/20
    @Spinx_Ra
    Sure you can: def_UMSDdisk.info
  • »11.04.04 - 17:14
    Posts: 47 from 2004/4/11
    new here :D nice site!
    I have a question about deficons. i've changed the def_drawer.info with copyicon and when i create a new drawer now with an icon and open it then the drawer opens in full ambient size -> 1024x768. How can i fix this? :(
    Bye
    TriMa
  • »11.04.04 - 18:46
    Toto
    @Mosimo
    Snapshot a drawer in the size you prefer and than copy that drawer icon as def_drawer.info. That should work.
  • »11.04.04 - 19:01
    Quick answer:D
    But it doesnt work. :(
    Bye
    TriMa
  • »11.04.04 - 19:06
    Toto
    @Mosimo
    Well, it works for me. This is what I did:
    Make a new drawer with the drawer icon you like. Snapshot this drawer
    in the size you want then copy the drawer icon to
    sys:prefs/env-archive/sys/def_drawer.info. Now reboot and it should
    work (it only works after a reboot).
  • »11.04.04 - 19:27
    Ah fine, thanx it works now!:D
    Bye
    TriMa
  • »11.04.04 - 20:02
