Broadband with Miami demo?
    Robert
    Posts: 331 from 2003/5/12
    Anyone know if it's possible to connect to ADSL
    with the demo version of Miami. (You can't register
    it anymore)
    Also, someone else said MiamiDX is on aminet.
    Is it freeware now?
    Robert.
  • »10.04.04 - 15:16
    Donar
    Posts: 142 from 2003/12/27
    MiamiDX is not Freeware, it is only the Demo on Aminet.
    You should be able to connect to the internet through
    ADSL with the Demo Version of MiamiDX. The PPoE
    device should work, but you will be disconnected
    after 30 Minutes.
    Bye
  • »10.04.04 - 15:25
    MaSC
    Posts: 63 from 2003/12/1
    one way around the disconnection is to set up a arexx script that disconnects and re-connects miami every 20 mins or so. This resets the timer of the cut-out and the dis and re-connection is quick enough that it shouldn't bother you.
  • »10.04.04 - 20:29
    magnetic
    Posts: 2129 from 2003/3/1
    Heh
    Nice trick. Never heard of that one before. Bravo
    magnetic
  • »10.04.04 - 20:54
    Chain-Q
    Posts: 347 from 2003/10/12
    What about when using provider with dynamic IP? Even most DSL providers do that. Reconnecting changes the IP in most cases, so it would break sustained connections like IRC, streaming radio, so on...
    [.Hosting AmigaSpirit.hu.]
  • »11.04.04 - 02:47
