How to set Morph to read DVD
    Nitro
    Posts: 106 from 2003/8/24
    I`m new to MorphOs, can someone tell me what to
    do, to mount my DVDs, or DVD data?
  • »08.04.04 - 15:18
    palpatine
    Posts: 49 from 2003/3/7
    AFAIK you shouldn't have to do anything, just connect the drive like a CD-Rom and it should read DVD's, at least data DVDs...
    Cheers,
    Ron
  • »08.04.04 - 15:21
    Nitro
    No It only reads cdrom for some reason. It doesn`t matter what format Win,Linux,Mac, or Morph cdroms work, just not any type of DVD.
    and of course it is a DVD drive :-)
  • »08.04.04 - 15:30
    palpatine
    Mm, weird. I tried several on the Pegasos 1 and 2 here, ranging from a cheap noname dvd rom drive to a nec 1300 dvd rewriter, they all worked and read various data dvd's...
    Cheers,
    Ron
  • »08.04.04 - 16:00
  • Ray
    Ray
    Posts: 21 from 2003/2/24
    Above 4GB too? Not for me. :(
  • »08.04.04 - 22:43
    palpatine
    Yes, biggest DVD I read in and copied to HD was about 4.2GB
    Cheers,
    Ron
  • »09.04.04 - 07:28
    DethKnight
    Posts: 139 from 2003/6/24
    Slightly unrelated here but,
    just to add more clues or confusion,
    A buddy brought over his burn of a DVD. It was burned onto a 4.7GB DVD+RW media.
    His machine could play it, mine could not even detect the media.
    My machine (an x86 linuxPC) :-( plays ALL commercial DVDs from retail/rental that I have thrown at it. But I never tried DVD+RW init until last nite. So maybe its a dvdrom problem?
    just to add my 2cents of confusion....your welcome
    I am ; therefore you are
  • »09.04.04 - 16:51
    Neko
    Posts: 301 from 2003/2/24
    It has to be an ISO DVD, and not a UDF DVD.
    If it's UDF, then you won't be able to mount it without a UDF filesystem.
    Neko
    Matt Sealey, Genesi USA, Inc.
    Developer Relations
    Product Development Analyst
  • »09.04.04 - 17:46
