Home
Forums
Library
Links
Bounties
Login Block
Nickname
Password
Lost Password?
Don't have an account?
Register now!
Search
Advanced Search
Forum Index
User Forums
Applications
gui for mame?
ocs
# 1
Posts: 47 from 2004/4/3
Hello, what libs i need for the default GUI of MAME?
09.04.04
00:32
Fab
# 2
MorphOS Developer
Posts: 1331 from 2003/6/16
At the moment, you need guigfx.mcc, available on aminet.
By the way, check that you have a prefs/ directory in mame/. Empty directories may have been skipped during extraction.
09.04.04
00:44
ocs
# 3
more Thanks.
And i have the same problem for the uae emulator.
What i need?
09.04.04
08:15
Wishmaster
# 4
Posts: 342 from 2003/6/29
Hello, one more new AmigaOS/MorphOS user !
Use SnoopDOS to check out what is missing.
Pegasos PPC
09.04.04
12:35
