Posts: 204 from 2003/12/29
Hello,
I brought my Peg2 home (I used in my lab before), and changed the monitor to a LCD Screen. The frequency with the resolution I had set before does not match, so I can't see anything in MorphOS.
From the linux side, I moved the monitor file I created before outside the Presets dir, and now I can see the MorphOS logo while booting, but nothing else.
Which are the files related with the screen mode? Can I edit them from outside (linux)? I tried renaming these files, to see if I got a default config:
/boot/Prefs/env-archive/sys/PublicScreens.prefsDISABLED
/boot/MorphOS/Prefs/mprefs/ScreenMode.mprefsDISABLED
Thanks!
Pegasos II G3@600Mhz (no fan) 512MB RAM (1 slot)
-- Maxtor 6Y120P0 120GB, 7200 rpm -- ATI Radeon 7500 - (64MB, TV-out)
-- Minuet Slimline PC case -- MorphOS 1.4.5 + Gentoo
EFIKA
