Iris - An upcoming E-Mail client blog
    Posts: 52 from 2003/4/9
    Unfortunately (or fortunately) I have 2 step auth turned on, so then google says to use app passwords. Well since Iris still sends me to the google log in page that says the web browser is insecure. So no go that rooute, thanks fro the reply...
    Rob
  • »09.06.20 - 17:13
    Posts: 3342 from 2003/3/5
    I’m quite sure the Odyssey path is working fine. On the page warning the client is insecure, you have to expand the text below the message to reveal a button that will let you go forward. If this does not work, either delete cookies or change browser spoofing.
  • »09.06.20 - 20:05
    If I could find a screen capture app for MorphOS I would send that to you. This is what shows but there is no text to expand.
    [i]Couldn't sign you in
    robbhar@gmail.com
    This browser or app may not be secure. Learn more
    Try using a different browser. If you’re already using a supported browser, you can refresh your screen and try again to sign
    in.[/i]
    I have tried all spoofing settings and cleared the cache, no go...
    Rob
  • »16.06.20 - 15:34
  • ASiegel
    Posts: 1399 from 2003/2/15
    You will find one in the "Utilities" folder of your system partition. It is called "Grabber".
  • »16.06.20 - 16:14
    Posts: 919 from 2004/1/24
    robbhar@gmail.com
    in.[/i]
    Rob
    Well, you could use "Grabber" which is located in your MorphOS/Utilities directory or install the rather brilliant Screenshot Screenbar-Plugin V1.2...
  • »16.06.20 - 16:16
    Funky. I've just enabled 2FA by phone on one of my gmail accounts to test this and account setup proceeded normally. You will get the "This app isn't verified" warning post logging in, where you have to click on Advanced, and Go to Iris (Unsafe), then finally click on Allow in the last step.
    Some screenshots could indeed help...
  • »16.06.20 - 23:38
    good grief how do I get an attachment to stick? it's a png file only 28k I select file press + and when I preview it is gone?
  • »20.06.20 - 14:12
    Error: 1: /var/www/morphzone.org/modules/newbb_plus/cache/attachments/ does not exist or is not writable.
  • »20.06.20 - 14:18
    You can always email the screenshot to me directly or put it on some img hosting service.
  • »20.06.20 - 23:24
    https://ibb.co/FBdrGnY
  • »22.06.20 - 18:34
    Did the screenshot link not work?
    Rob
  • »24.06.20 - 18:10
    Yes, sorry, didn't have time to research this. Not sure what could the cause be. If you cannot log into Google from Odyssey (without going through the Iris configuration), then it likely means that some of your settings (not 2FA itself) is preventing the login. I can only guess which one since people seem to be getting this error due to many different issues it seems.
    I don't think I've tried using any Google login workarounds, so maybe try with that disabled.
    I'm looking into getting Iris certified in the next couple of weeks, so perhaps that helps. It seems you're the only 1 person actually being blocked from signing in to Google. Certainly odd.
  • »24.06.20 - 18:38
    zbysiuk
    Posts: 59 from 2006/8/4
    ... robbhar isn't the only one - disease is spreding, my account has been affected too.
  • »16.07.20 - 08:20
    I've taken steps to make Iris a verified app, but unfortunately, the process may take several weeks (at Google's discretion).
  • »16.07.20 - 10:24
    zbysiuk
    No, problem. I'll wait - thank you.
  • »16.07.20 - 11:34
    Google has rejected the application. I'm currently evaluating my options. Dedicated support for GMail is likely to stop working at any time (at Google's mercy).
  • »21.07.20 - 13:52
    Posts: 141 from 2017/8/6
    You can still set "less secure app' support in the Google account settings. Ive done that too, i dont like the gmail app. they just call every other mail app less secure, it means nothing.
  • »21.07.20 - 14:07
    Posts: 126 from 2003/2/17
    any explanation from them ?
  • »21.07.20 - 16:38
    Not really, no. I do have a Plan B now, though. Stay tuned.
  • »21.07.20 - 16:47
    redrumloa
    Posts: 1424 from 2003/4/13
    You really have an uphill battle ahead of you. Kudos for even trying to deal with a soulless company.
  • »21.07.20 - 22:38
    Posts: 849 from 2007/10/23
    Like AWS if Amazon somedays says "you are not a credible partner anymore".
  • »22.07.20 - 06:27
    Luckily the issue was now resolved and Google has verified Iris. This should remove all restrictions that people have previously faced when trying to configure an account in Iris.
  • »25.07.20 - 16:10
    Posts: 2732 from 2003/2/24
    That is fantastic news! :-D
    Officially verified by Google, now how about that...
  • »25.07.20 - 16:34
    MoerBoer
    Posts: 240 from 2019/10/15
    Sweet, working like a charm with GMail.
  • »26.07.20 - 06:18
