RSS Reader?
    Posts: 40 from 2019/9/5
    AmRSS doesn't support https, so it is useless at this point. Do you have any RSS reader suggestions?
    Thanks.
  • »09.01.20 - 00:30
    Posts: 2220 from 2003/2/24
    RNOWidgets has an RSS reader widget, and it supports HTTPS if you install AmiSSL v4.
    BTW. when installing AmiSSL first time (no previous assigns), you have to add assigns to the S:user-startup yourself, because the current installer bugs regarding this on MorphOS.
    The required lines are:
    Assign AmiSSL: "Path:To/Your/AmiSSL"
    If Exists AmiSSL:Libs
    Assign LIBS: AmiSSL:Libs ADD
    EndIf
    Path AmiSSL: ADD
  • »09.01.20 - 04:02
    Thank you, I'll try this.
  • »09.01.20 - 12:31
    connor
    Posts: 650 from 2007/7/29
    AmRSS is even open source: https://sourceforge.net/projects/amrss/. Or here: http://aminet.net/package/comm/www/amrss. Is Alfonso still an active MorphOS user?
    Maybe someone wants to bring SSL to it. Because it is a much smaller program than the RNO Widgets.
  • »23.01.20 - 15:52
    Posts: 12572 from 2003/5/22
    I haven't seen anything from him after 2008 at least.
  • »23.01.20 - 16:32
