Mplayer V.1.3.0
    Mozzerfan
    Posts: 105 from 2016/10/5
    Hi all,
    Does Mplayer v.1.3.0 from morphos-storage.net use altivec? Because it works on my macmini and ibook, but it crashes on my sam460.
  • »25.10.19 - 07:11
    Posts: 12572 from 2003/5/22
    MorphOS builds of MPlayer should have AltiVec runtime detection, at least Fab's older builds had. If this fails for some reason, you might try with the -noaltivec option.
  • »25.10.19 - 07:25
    Mozzerfan
    Thanks Andreas. I just tried with the -noaltivec option. It still crashes.
  • »25.10.19 - 07:37
    Posts: 611 from 2003/4/11
    It sounds like the build still has some issue with non Altivec systems. This actually is some beta version I've been working on last year which did not get tested properly on non-Altivec MorphOS systems like Sam460/Efika&X5000, unfortunately.
  • »25.10.19 - 08:01
    Mozzerfan
    OK. Thank you for clearing that up. I hope that a version that also runs on non-altivec systems will appear in the future.
  • »25.10.19 - 08:09
    Posts: 1390 from 2010/1/6
    Last runnig version on CPUs without ALTIVEC is MPlayer V1.0 (18.4.2013).
    If you can't find it -> PM. I have that one on my Efika.
  • »25.10.19 - 15:32
    Mozzerfan
    Thanks, but I checked the version I'm running on my sam460.
    It's version 1.1
    I think I got it from Fabs' site.
    [ Edited by Mozzerfan 25.10.2019 - 20:05 ]
  • »25.10.19 - 16:02
    Interessting! V1.1 won't work on Efika....(I've no SAM).
  • »25.10.19 - 19:59
