ImageFX problem on Mac
    vulture
    Posts: 198 from 2008/2/4
    Hello guys!
    So here's a problem regarding ImageFX not present on MorphOS 3.11 on a Peg2 , but only on a Mac:
    Upon start, right after its screen appears, the whole OS freezes. That's on a G5, but also happened on a dual G4. Thumbnail.library is in libs: and, besides, I've set the requesters to use asl anyway, so, that's not it.
    Needless to say, I've reinstalled both MorphOS and the application without any change.
    As I said, under the same conditions on Peg2, it works just fine.
    Any help, highly appreciated.
  • »05.09.19 - 17:50
  • ghh
    ghh
    Posts: 60 from 2017/7/15
    I remember crashing ImageFX if a font that is not on disk was set in the settings.
    But it works for me (ImageFX4.5) on all computers (PB, G4, G5), so I don't know ...
  • »06.09.19 - 21:54
    Posts: 2217 from 2003/2/24
    Works on Mac mini here... have you tried to copy your ImageFX installation (directory) from Peg to Mac? Or just the Default.prefs file? Or have you tried to rename the Default.prefs file out of use and see what happens then (should pop up a screenmode requester first)?
    And when you say its screen appears, is the new screen empty or does it draw some graphics or the control panel there?
  • »07.09.19 - 05:55
    _coliN_
    Posts: 70 from 2003/4/30
    In my setup on a Peg1 the settings for Vmem often caused some trouble and such behaviour...
  • »07.09.19 - 17:55
    vulture
    Thx for the answers guys. I'm gonna try the fonts suggestion. I've already tried to copy the installed dir from peg and the default.prefs file to no avail, but thx for the suggestion.
  • »07.09.19 - 21:48
    NewSense
    Posts: 1615 from 2012/11/9
    I use IFX v4.0 and I rarely have issues with it, but I always had issues with v4.5 installing, so I avoid it, as I'm not that bothered about the slight improvements that were made, as I think some of the stability was compromised prior to 'Kermit' Woodall selling the program to A-Eon. It was also very annoying that he never supplied a manual even on PDF for IFX v4.x as he said he intended to, I believe, so some of what is in that release of the program is almost guesswork when using it. :-?
    I have the v2.1 printed book, and the v3.x and v4.x update manuals, prior to v4.5, but having ALL the updates in one manual would have been a major improvement. ;-)
    I know he sold - through a third party bookseller - a version of IFX v4.5 as a printed version, but it was overly expensive I seem to remember, and I don't think it's for sale anymore anyway. :-(
  • »08.09.19 - 05:03
    vulture
    I think I've 4.0 version somewhere as well, gonna try that too
  • »08.09.19 - 15:01
    I have 4.5 in use on MorphOS, but I have copied the installation from my A1200... can't remember how I installed it there back then :)
  • »08.09.19 - 16:06
  • ghh
    ghh
    You need some ClassAct gadgets (chooser.gadget, ...) and sys:classes/images/bevel.image. I also copy Rexxc directory to sys:
    ImageFX is my second most favorite program :)
  • »08.09.19 - 19:27
    vulture
    I think I had copied those, but I'll take another look, thx :)
  • »09.09.19 - 14:08
    vulture
    small update, I found out that since I stopped ImageFX from opening the palette window at startup, the freeze was gone. Sure enough, once I hit the palette to appear it freezes again. That's progress I guess, still unusable, but something to investigate.
  • »09.09.19 - 18:02
    You mean that "Preview" window? What do you have in Prefs/Modules/Preview selected? Not that any of those would crash here either, but WindowedCGX would probably be the best... or maybe this uses some of those ClasAct gadgets and you still miss or have wrong version?
  • »10.09.19 - 03:05
    vulture
    No, not the preview window. I can load images and apply fx fine, but the moment I click for the palette window to appear (to select a colour), it freezes. Hence, it's unusable if I can't spray things on images with fx. Now, I've copied the gadgets and images from the classes dir of peg2 and it's still the same. Baffles me! I'll try different preview modes too, but I think I've done this before to no avail. I'm currently using WindowedCGX.
  • »10.09.19 - 14:07
    For some reason the palette window seems to be called as "Preview" in ImageFX... see the window title text. And if you change Modules/Preview prefs, it affects to the palete window :)
  • »10.09.19 - 14:30
    vulture
    Ah.....I see, hadn't noticed that! Then yes, that's the one :)
  • »10.09.19 - 18:11
