Posts: 1615 from 2012/11/9
Have you set EaglePlayer> Engines> AHI Amplifier to
Active?
I just loaded Chaos Engine.mod into EaglePlayer 2.0.5 (21.11.2016) and it's all playing as expected.
Even though I rarely use EaglePlayer thesedays for .MOD files as I often just let them load/play with MorphOS menu option 'PLAY' which is available for these files by default, and they play continuously until a Cmd+C (Break command) is made.
