Sharing MorphOS FS with Linux
    deka
    Posts: 136 from 2013/2/12
    Hello,
    I would like to share a directory with a Linux computer. I still handle my photos on my Power Book because I really like ShowCase for this task, but the syncing is easier on the Linux side.
    Is it possible to do this?
  • »31.01.19 - 07:22
    Korni
    Posts: 473 from 2006/2/23
    rc-ftpd works fine on MorphOS.
  • »31.01.19 - 10:59
    deka
    Thank you... I'll check it.
  • »31.01.19 - 13:42
    Tom01
    Posts: 187 from 2009/9/20
    You could setp a Samba-Share.
    The old 68K Samba-Port still works with Linux.
    The PPC-MorphOS-Port does not work.
    [ Edited by Tom01 31.01.2019 - 17:43 ]
  • »31.01.19 - 15:42
    Posts: 2217 from 2003/2/24
    Or use MirrorCopy or similar to sync files from MorphOS side after all, because there are better options to mount drives in other direction...
  • »31.01.19 - 15:49
