MUIPlot - a simple function plotter
    zukow
    Posts: 662 from 2005/2/9
    I and Krashan made similar class 10 years ago :)
    https://web.archive.org/web/20120129135957/http://brain.umcs.lublin.pl/~rzookol/download/plot_221108.lha
  • »14.11.18 - 05:34
    Posts: 139 from 2015/3/31
    Funny,
    but the plot component is not the new here ;) I use it long time already
    in MUIMapparium for example:
    MUIMapparium with a Track
    The only conversion here was to a full FreePascal "MUIClass".
    I'm working on the parser behind it... (atm. convert it to a compiler to byte code) I also planed such thing like your program but with fitting (put a formula in and let it fit to the data)... If I have time :-P for that I need the compiler, for now it speeds up the calculation at m68k dramatically.
    P.S. just curious, someone knows a mui mcc which allows to make tables which can be edited? like a spreadsheet? Does something like this exists?
    [ Edited by ALB42 14.11.2018 - 13:53 ]
  • »14.11.18 - 11:51
