Flowstudio and utf-8 encoding
    emeck
    Posts: 175 from 2014/7/15
    Hello,
    I opened an html file in Flowstudio and some characters were not displayed correctly. Tried again with "Use utf-8" option active and same result. NoWinEd displays the characters correctly when opening the same file.
    So, am I missing some extra setting or is it not working for now?
    I'm using english locale but spanish keyboard.
    Edit: writing specials characters in Flowstudio and saving with utf-8 encoding does work.
    [ Edited by emeck 04.05.2018 - 16:52 ]
    PowerBook 5.8 MorphOS 3.18
    Mac Mini MorphOS 3.18
  • »04.05.18 - 12:45
    Posts: 3296 from 2003/3/5
    Switch to a ttengine font in Flow's settings.
  • »04.05.18 - 13:43
    emeck
    @jacadcaps
    thank you very much!
  • »04.05.18 - 14:10
    emeck
    Opening a file from FlowStudio works but dragging a file to FlowStudio's window doesn't. I have added tooltype=utf-8 but no change for dragging files.
  • »17.05.18 - 16:18
    emeck
    Solved Setting Encoding to UTF-8 and checking Make default in ASL requester allos correct UTF-8 detection when dragging files to FlowStudio or openning with filetype configuration.
    Thanks again Nicholai and jacadcaps..
  • »09.06.18 - 07:00
