regex in FlowStudio
    emeck
    Posts: 173 from 2014/7/15
    Hello, I'm trying to use some simple regex in FlowStudio but no luck.
    This is what works for me in SciTE for adding an id to a <sup> tag:
    In Find field: <sup>\(\d+\)</sup>
    In Replace field: <sup id="nota_$1">$1</sup>
    If I just use the Next button, al the matching strings are found and selected. When I use Replace&Next, next string is found and selected but previous is no changed. If I use Replace button then "No matching string found" message appears.
    What am I doing wrong?
    [ Edited by emeck 17.05.2018 - 20:34 ]
    PowerBook 5.8 MorphOS 3.18
    Mac Mini MorphOS 3.18
  • »17.05.18 - 18:34
    emeck
    @anybody interested
    it has been fixed for the next release.
    Thank you, Nicholai
    Edit: typo
    [ Edited by emeck 09.06.2018 - 10:57 ]
  • »09.06.18 - 08:57
