Word wrapping in textinput.mcc 30.0 does not work
  • MDW
    MDW
    Posts: 498 from 2003/7/25
    Word wrapping function doesn't work in Ed from MorphOS 3.10. If I check "Word wrapping" in context menu of Ed, text still is not wrapped. Generally word wrapping doesn't work in each application which uses textinput.mcc. I use standard textinput.mcc from the latest MOS 3.10:
    Textinput.mcc 30.0 (2018-03-22)
    (C) 1997-2003 Oliver Wagner, (C) 2012 Stefan Stuntz, 2014-2018 Jacek Piszczek, Michal Wozniak, PPC, MorphOS, DEBUG
    Is it bug or feature? :)
  • »22.05.18 - 15:46
    Posts: 3336 from 2003/3/5
    Sounds like a feature to me ;) Thanks for the report, we'll have a look.
  • »23.05.18 - 10:05
  • MDW
    MDW
    I have already sent bug-report in standard MorphOS bug reporter. I hope, the report was sent correctly (button "Send" becomes inactive after send).
    I very like Ed from MorphOS and use often for write a text. However text editor without word wrapping function can't be used for editing texts other than sources/scripts (like Ed from AmigaOS 1/2/3).
    Thank you!
  • »23.05.18 - 15:57
    NewSense
    Posts: 1618 from 2012/11/9
    I'd have to say that Ed, Multiview, and probably others from the Amiga days have never seemed to get Word-Wrap to work as it should.
    The best, within MorphOS, IMHO, is/was Scribble as it also had "word wrap" icons at the end of a "wrapped" line. NoWinEd is also good, but lacks the "word-wrap" icons, and other features that Scribble has. I have only used FlowStudio a little, but I can see that this word-wrap feature works basically as it does in Scribble, so that's good.
    Notepad++ is superior with more features, and I'm surprised that its GNU General Public License hasn't encouraged those that can do such conversions from such source code to have a go at making it work with MorphOS, as it would be a great addition to our software library.
  • »23.05.18 - 18:32
    asrael22
    Posts: 453 from 2014/6/11
    Afaik both Notepad++ and Scribble/Flow Studio are based on Scintilla (https://www.scintilla.org) for the base editor component.
  • »23.05.18 - 18:57
    NewSense
    I believe that's correct ( Notepad++ and Scribble/Flow Studio are based on Scintilla ), but Notepad++ has more features, and if we had Notepad++ then it would also be more inline with other OS's for file swapping, and plugins, etc., which surely wouldn't be a bad thing.
    There's also a Hollywood add-on for Notepad++ I seem to remember. Though there's also ones for Hollywood for CubicIDE, UltraEdit and VIM.
  • »23.05.18 - 23:31
    I've checked and there have been no changes in regards to word wrap in Ed and Textinput within a 4 year timeframe. I have, however, tweaked Ed a bit and wordwrapping will be available from 3.11. Mind that TI only supports wrapping as you type - there is no "load to see your document wrapped" mode.
  • »23.05.18 - 23:49
  • MDW
    MDW
    Yes, you are right - classic old Ed can’t wrapping text. It was very simple program for edit startup-sequence. :) I am glad Ed in MorphOS can be used as simple text editor for each text, not only a script.
  • »24.05.18 - 03:12
  • MDW
    MDW
    I am almost sure MOS Ed wraped document always. Also when I just loaded text file. I have no previous versions of MorphOS so I can’t check.
  • »24.05.18 - 03:18
    Posts: 2220 from 2003/2/24
    "Edit" or some would say "break" :D The old 68k Ed cuts the long lines without telling it (doesn't wrap, just cuts the lines at certain length and rest of the lines are lost). It always broke my lengthy BlitzKick lines when I forgot that and edited the startup-sequence with it.
  • »24.05.18 - 03:30
    @MDW: you must have used a different application for this - there really isn't any code to support wrapping on resize in String.mui (TI.mcc is just a mostly empty wrapper).
    Why not use Flow Studio? It handles wrapping just fine.
  • »24.05.18 - 09:39
