WMA and OGG files
    Spidey
    Posts: 568 from 2003/2/24
    Hi everybody,
    Are there tools to convert WMA- and OGG-files to AIFF (or MP3)?
    Bye,
    Spidey
  • »27.03.04 - 18:30
  • elf
    elf
    Posts: 32 from 2003/5/24
    This may sounds a bit odd, but what the heck: use Frogger ;) ao=AIFF, select output file name, press play, and after a while you will have aiff file ready to play/use.
  • »27.03.04 - 21:40
    Jupp3
    Posts: 1193 from 2003/2/24
    I think there's tool to convert ogg file to wav file in vorbistools...
  • »27.03.04 - 21:59
    Spidey
    Hi elf,
    Thank you very much. I tried it with an OGG-file, worked perfectly!
    Hmm, now to try with a WMA-file.
    Bye,
    Spidey
  • »28.03.04 - 20:57
