GoogleDrive
    Jeckel
    Posts: 133 from 2007/3/11
    Hi all,
    Is there any way to make this work?
    http://aminet.net/package/comm/tcp/GoogleDrive_handler_MOS
    It is required to go to https://goo.gl/1K3xoq to obtain a client code, but this URL does not work anymore.
  • »14.12.17 - 07:13
    Posts: 2217 from 2003/2/24
    Hmm.. when I first clicked the google link, it did seem to work and I got the login page, but now when doing it again I get the error page...
    BTW. here is a newer version of the handler (although doesn't help with the actual issue): http://aminet.net/package/comm/tcp/AmigaCloudHandlers
  • »14.12.17 - 11:54
    bennymee
    Posts: 136 from 2004/4/14
    Jeckel wrote:
    Hi all,
    Not in Edge, but it does in Chrome. I got this:
    Enter this code into amiga-handler to finish the process.
    <8qty etc etc >
  • »15.12.17 - 11:54
    Jeckel
    Ok. No way to make it work here. I always have the same message:
    https://goo.gl/1K3xoq – this goo.gl shortlink has been disabled. It was found to be violating our Terms of Service. Click here and here for more information about our terms and policies respectively.
  • »15.12.17 - 14:07
    bennymee
    In MS Edge I had that similar warning.
    [ Edited by bennymee 18.12.2017 - 07:12 ]
  • »16.12.17 - 08:03
    Sir_Lucas
    Posts: 112 from 2006/4/23
    Jeckel wrote:
    Hi all,
    Have you tried this link?
    https://accounts.google.com/o/oauth2/auth?scope=https://www.googleapis.com/auth/drive&redirect_uri=urn:ietf:wg:oauth:2.0:oob&response_type=code&client_id=641021021914-0f5goga25u7mo14eclhdkqlpc8hueirs.apps.googleusercontent.com
    Hope it helps.
  • »16.12.17 - 20:38
  • MDW
    MDW
    Posts: 498 from 2003/7/25
    The Dropbox/GoogleDrive handlers for AmigaOS4/AmigaOS3/MorphOS are in unfinished alpha-version. They are unusable because basic functionality doesn't work. I've registered full version and signed in but I don't use these handlers. If I need to use Dropbox, I open web-version in OWB. It is not comfortable but works.
  • »17.12.17 - 09:46
    BSzili
    Posts: 570 from 2012/6/8
    The there is a new version out on Aminet with new links to get the client codes. The Dropbox one was also updated to the new v2 API, since they are shutting down the old one.
  • »17.01.18 - 14:23
