Posts: 498 from 2003/7/25
TheMagicM wrote:
I think on FreeNAS I enabled SMB3 and I couldnt mount it under MorphOS. Currently its set at SMB2.
You are right. SMB3 probably is supported by MorphOS version of SMBFS. I found in
SMBMounter.guide this information:
Finally, the current AmigaOS version of SMBFS has trouble connecting to Windows Vista, 7 and MacOS X 10.8+ shares, resulting in file corruption issues, in which case there's not really a lot that can be done I'm afraid. These systems use a newer version of the SMB protocol than the AmigaOS build of SMBFS supports. Some people have reported various hacks and registry tweaks which enabled Samba from the Windows side to work the "old" way, but I haven't attempted this myself. The MorphOS port of SMBFS works fine with the new version of the SMB protocol used by these systems.I am able to coonnect to the Mac from another Mac and I have access to its Public and other shared folders. So the SMB on this Mac works good.
I have acccess to folders on my NAS (WD MyCloud 2TB). So SMB on MorphOS works good.
So... I don't know why I can't connect to shared folder on my Mac's disc from my MorphOS machine. Does anyone have any idea what else I could do?
