easy coder - port 5K cando exe to PPC
    MrZoon
    Posts: 48 from 2003/6/1
    cando/cando apps crash under morphos on ppc - i wonder how hard it
    would be to disass the core exe and make a ppc-able lookalike? Or
    maybe someone could make a similar tool for folks who don't have the
    time or inclination to learn C..
    Over ~10000 people bought cando back in the day; I for one have
    literally hundreds of little things written with it. And some larger
    projects which are under construction.
    There are several fairly mature, large/complex apps out there that
    could add to the tastiness of the soup...
    Just a thought..
    [ Edited by MrZoon on 2004/10/24 17:46 ]
    MrZoon ~8
  • »24.10.04 - 19:43
    Posts: 2090 from 2003/6/4
    I guess it is damn close to unhealthy behaviour to start a
    disassemblation of CanDo. If the sources are not available simply
    forget it.
    But if you need a replacement for CanDo give Hollywood a try. Easy to
    learn, quite mighty in functions. Not good to replace your previous
    work, but a good tool for future work. I can recomment Hollywood
    without any restriction, it's really a pretty cool pice of SW.
  • »24.10.04 - 21:06
    Robin
    Posts: 741 from 2003/2/24
    In the beginning I loved CanDo.
    But when I learned more an more
    I've learned too that it has too many limitations.
    First I replaced it with MUIRexx and
    now there is RxMUI for powerfull MUI-Tools and
    Hollywood for everything else.
    Both are more powerfull than CanDo.
  • »25.10.04 - 07:54
    Posts: 20 from 2017/3/16
    Thank you all for your suggestions. I shall look into Hollywood
  • »18.04.17 - 23:09
    Posts: 2217 from 2003/2/24
    And nowadays there's MUIRoyale for Hollywood, so you can create MUI apps with it too.
  • »19.04.17 - 02:58
