Wireless networking
    Posts: 20 from 2017/3/16
    I have a macmini g4 without wifi, so I bought an rj45 usb dongle to enable wireless networking. The device is definitely recognized in Morphos usb but it is not bound as far as I can tell. I am not sure what binding class to apply to it.
    The result is that when I go into network interfaces, I see no sign of it and nothing under w10. So I cannot access it. All I can access is my ethernet, but nothing wifi.
    Has anyone had a similar problem? If so, how does one solve it. Any advice would be appreciated. Thanks in advance
  • »18.04.17 - 06:59
    Posts: 12572 from 2003/5/22
    Only certain chipsets are supported by MorphOS, see here.
    An "rj45 usb dongle" enables wired networking through USB. Are you sure what you have is an "rj45 usb dongle"? If so, what you need instead is what's been called "wifi rj45 dongle" by ppcamiga1.
    > w10
    wl0
  • »18.04.17 - 08:50
