Home
Forums
Library
Links
Bounties
Login Block
Nickname
Password
Lost Password?
Don't have an account?
Register now!
Search
Advanced Search
Forum Index
User Forums
Applications
Diavolo Backup bug
TheMagicM
# 1
Posts: 1218 from 2003/6/17
Backing up my SYSTEM partition is fine. Backing up WORK isnt. I get an error:
file 'Work:Development/GG/bin/addr2line/a2p' could not be opened for reading.
DOS Error message: object is not of required type
EDIT:
Looks like the addr2line is a symlink. That could be the problem. I'll see if I can get around that.
[ Edited by TheMagicM 05.03.2016 - 16:59 ]
05.03.16
22:58
TheMagicM
# 2
So yea.. Diavolo backup doesnt like symlinks. Needs fixing.
14.03.16
12:29
# 3
MorphOS Developer
Posts: 1520 from 2003/2/24
I can take a look.
14.03.16
18:13
TheMagicM
# 4
Thanks itix!
14.03.16
18:13
Ingo
# 5
Posts: 103 from 2004/3/20
itix wrote:
I can take a look.
Hey Itix,
while you are looking, you can also check out
the long standing BUG in the scheduler ;)
Just search for SystemTagList in the deamon and you find the problem.
Ingo
17.03.16
18:58
TheMagicM
# 6
@itix:
Did you get a chance to fix the bug?
28.11.16
01:05
