E-UAE JIT 1.0 Wb 3.9 emulation problems
    Elowan
    Posts: 214 from 2011/4/18
    hi there,
    maybe you folks know, what´s wrong:
    I got a OS3.9 install on my Win10 PC, which works fine. I set it up in FS-UAE, I have some folders, that represent the harddisks of the Amiga.
    Now, I installed UAE4ALL and E-UAE 1.0 to my MorphOS 3.9 ibook and did a new config (.uaerc) and try to boot my transfered 3.9 Amiga WB...
    It boots, but I run into some issues:
    The colors are just 8bit (or less?), everything is just grey-blue-ish. the Workbench does not fit into the screen and the mouse pointer is "off". Like I can move half across the E-UAE window, then it get´s stuck and the mouse pointer is on the Morphos desktop again. (There is a big gap)
    Can somebody tell, what´s wrong? How to "catch/capture" the mouse-pointer?
    Cheers!
    [ Editiert durch Elowan 09.08.2016 - 12:03 ]
    12" ibook G4 1.33Ghz, 1.5GB RAM, ATI 9550 32MB, 16GB SSD, WiFi, BT, ComboDrive
  • »09.08.16 - 08:26
    Korni
    Posts: 472 from 2006/2/23
    To have more than 8-bit colors and higher resolutions etc. you need a gfx card emulation. This is only supported by euae sdl afair. Mouse pointer breaks when emulated amiga screen is in different aspect ratio than a regular screen.
    [ Edited by Korni 09.08.2016 - 13:11 ]
  • »09.08.16 - 10:08
    Elowan
    ah, great!
    thanks for answering...
    Now, I have euae sdl started, but still just 8-bit colors... do you know the command for "gfx-card"?
    In FS-UAE I used something like: graphics_card = uaegfx / graphics_memory = 131072uaegfx .. but it´s not working in Morphos e-uae :(
    Oh and another thing: how fast is emulation, compared to other OS´es?
    Is it better, to emulate just WB 3.1 or lower on ibook 1.33Ghz, running Morphos 3.9?
    [ Editiert durch Elowan 09.08.2016 - 13:18 ]
  • »09.08.16 - 10:16
    Korni
    Add gfx_fullscreen_picasso=yes to euae config. I didn't try to run uae on other OSes on the same HW, so I can't say. Mostly I only need euae to run games (just by clicking in Ambient) and other programs which don't run on MorphOS and even then 000/020 OCS/AGA Amiga emulation is enough. 3.9 or 3.1? No, it doesn't really matter.
    [ Edited by Korni 09.08.2016 - 14:19 ]
  • »09.08.16 - 11:14
    Elowan
    awesome, thanks - I´ll try this
    You can start 68000er games, just by clicking them from the ambient desktop?
    Can you tell, how you did that? Is there kind of "run in uae" scripting going on?!
    would be nice, if you could tell a little more in depth about it...
    have a good one!
  • »09.08.16 - 11:40
    Elowan
    uuups - I already read the document you linked (parts of it)
    So Page 19. is the key ;)
    great tipp for the ADF images, nice
    thanks for the heads-up !!!
    [ Editiert durch Elowan 09.08.2016 - 16:10 ]
  • »09.08.16 - 13:09
    Norbi
    Posts: 99 from 2004/6/19
    add to .uaerc
    gfxcard_size=16
    Have You driver uaegfx in DEVS:Monitors: ?
    [ Edited by Norbi 10.08.2016 - 01:21 ]
  • »09.08.16 - 22:19
    Elowan
    hello,
    I tried adding "gfx_fullscreen_picasso=yes" to config and was hoping to have some more screenmodes in the Screenmodes tool on the amiga - but this wasn´t the case...
    I only get Pal low-res and high-res modes, like standard amiga would.
    There is no thing like a picasso, uaegfx mode or such :(
    The thing is, the mouse is allways totally off, when launching in a window. It only works when E-UAE is in fullscreen-mode.
    Even then, my workbench does not fit into...
    Does someone have a working .uaerc config file for a amiga workbench (not games)?
    Tried many resolutions in the uae settings, but nothing will work right.
    I am on a 12" ibook right now @1024x768px and I like to run the OS3.9 in 800x600 or maybe fullscreen.
    But would prefer windowed first...
    Maybe I have to set some custom res in amiga-screen-tool???
    @Norbi
    Yes, I have
    [ Editiert durch Elowan 10.08.2016 - 12:28 ]
  • »10.08.16 - 08:00
    Elowan
    great, "gfxcard_size=16" did the trick - now I get UAE screenmodes in the Amiga ScreenMode tool, up to 800x600 32bit (but no 1080x768) res...
    So I switched back to windowed UAE, but then once again, the mouse is totally "off".
    Is there no way to fix this issue? I mean in FS-UAE, you just press the mouse-scroll-wheel and boom - the poniters snapping together. I am missing such an option in morphos E-UAE right now.
    besides that, it is remarkable fast, even on an 1.33GH ibook G4! (ok, I set vsync and sound to none/off)
    cheers!
  • »10.08.16 - 11:50
    Elowan
    Still no luck...
    this is, how my config looks:
    filesystem2=rw,DH0:Workbench:HardDisks/Workbench,1
    filesystem2=rw,DH1:Work:HardDisks/Work,0
    filesystem2=rw,DH2:Games:HardDisks/Games,0
    kickstart_rom_file=PROGDIR:Roms/kick.rom
    gfxcard_size=32
    immediate_blits=no
    cpu_type=68020
    gfx_width=800
    gfx_height=600
    gfx_lores=no
    #gfx_linemode=double
    gfx_center_horizontal=smart
    gfx_center_vertical=smart
    gfx_fullscreen_amiga=yes
    sound_output=none
    #sound_bits=16
    #sound_channels=stereo
    #sound_frequency=44100
    cpu_speed=max
    chipset=aga
    gfx_vsync=false
    fastmem_size=8
    chipmem_size=4
    z3mem_size=8
    floppy_speed=0
    # joy<n> where n is lowlevel unit in amigaos target. In SDL target it's be the enumeration order.
    joyport0=mouse
    joyport1=joy1
    # overlay display
    amiga.use_overlay=yes
    # screen type (public, custom or ask)
    amiga.screen_type=public
    # slow and endianess issue.Better don't use
    #sdl.use_gl=yes
    any ideas, how to sync the mouse-cursor, when in windowed mode (turned it off in the config right now)
    Cheers!
  • »10.08.16 - 16:55
    Korni
    Are you sure that 1024x768 isn't in your screenmodes? It isn't sorted from lowest to highest. Here it works both on my pm and pb, even with your config. Euae on MorphOS seems to lack option to lock cursor to window.
  • »11.08.16 - 19:00
    Elowan
    Hmmm, I think I get only a few screenmodes, but nothing higher, than 800x600.
    I will check this again, maybe I´ve just overlooked it.
    No cursor lock in windowed mode is a bad thing - but I guess only the author can change this, so...
    I hope, fullscreen in 1024x768 will work.
    Thanks Korni!
  • »12.08.16 - 07:46
    Norbi
    ctrl+alt+g - lock cursor in windowed mode
    ctrl+alt+s - change between full screen / window
  • »12.08.16 - 11:58
    Elowan
    thank you Norbi, will test it as soon as I can :)
    [ Editiert durch Elowan 12.08.2016 - 15:57 ]
  • »12.08.16 - 12:07
    Elowan
    @Korni
    thanks for the hint, the screenmodes were not sorted, like I expected them to be... after I scrolled all the way up, I´ve found 1024x768 *yeah*
    @Norbi
    ctrl+alt+s works, but I noticed no difference with ctrl+alt+g - mouse cursor was still off.
  • »12.08.16 - 18:31
    Norbi
    Have You mouse cursor in kick's bootmenu ?
  • »13.08.16 - 10:31
    Elowan
    Hi Norbi,
    if you mean the "Insert Floppy bootmeneu", then "no" - got no cursor in there.
  • »15.08.16 - 07:59
    Elowan
    Ah, ok - yes, I get the Amiga-cursor, when in early startup-menu. It is still a bit "off", but not that much - at least, I can move it to the edges of the Amiga screen.
    And you know what: CTRL+ALT+G is now capturing/trapping the "Morphos Mouse cursor" and it works perfectly in windowed mode, too (!)
    I think, this one is solved!
    Thanks a lot
  • »16.08.16 - 08:07
