Posts: 1193 from 2003/2/24
Is there any chance to make the digicam working?
Buying standard USB memory card reader and plugging cameras memory card to that would likely help... I do that...
(assuming it has separate memory cards, and it uses "standard" FAT format for them...)
But even if the camera itself is massstorage compatible, there are at least 2 (fixable) things, that can make it not work...
1.No Fat95 installed, time to go to Aminet!
2.Few settings in Poseidon
