YAM ( last nightly build )
    VooDoo
    Posts: 189 from 2005/8/24
    After installing last YAM from 30.o3. Cant using it anymore.
    After click pn YAM icom loading is startin and sto on loadin interface..no crash, only yam startup request and that is all.
    Anyone have similar problem?
    Using last MorphOS version (registred) on MacMini.
    A1200 sandwich
    uA1c/g3 800 mHz/256mb/160gb hdd/OS4.1  :-D
    Warp croatian Amiga portal :
  • »07.04.16 - 05:52
    Posts: 611 from 2003/4/11
    See http://yam.ch/ticket/617
    Obviously YAM beta builds are built with some updated GCC5 cross compiler now which generates broken code most likely, so it is some generic MorphOS build problem not only affecting you.
  • »07.04.16 - 08:29
    VooDoo
    Other question is
    Is possible to connect and DL mail from Gmail whit Yam 2.9p1? I try but get ssl error
    Thanx
    A1200 sandwich
  • »10.04.16 - 06:34
    Tomo
    Posts: 94 from 2003/7/29
    My Gmail-account is set to send email automaticaly and directly forward....
    Regards Tom
  • »10.04.16 - 14:07
    Posts: 12572 from 2003/5/22
    Issue seems fixed.
  • »13.04.16 - 20:10
    analogkid
    Posts: 722 from 2004/11/3
    Yes, the latest nightly builds are working now.
  • »15.04.16 - 05:21
    VooDoo
    Yeah, same here.. last nighlty bulids fix the problem..
    A1200 sandwich
  • »15.04.16 - 06:30
