AVI4HV for MorphOS
    Cego
    Posts: 738 from 2006/5/27
    As some of you might know theres this AVI4HV tool, which converts AVI videos to the HV format. Those videos then can be played on a 68k Amiga.
    I wanted to ask if there's somebody interested and skilled enough to port that video converter to MorphOS.
    The source codes (AVI4AGA.BAS and AVI4HV.BAS) are in the archive and its written in FreeBasic AFAIK. Shouldn't be much of a great deal ? dont know... but i would be really happy if could do all the work on my G5.
    Here's the link to the archive:
    http://www.hyakushiki.net/junk/avi4hv.zip
  • »20.11.15 - 19:02
    pegasos-sigi2
    Posts: 265 from 2006/8/31
    FreeBasic is slow.
  • »20.11.15 - 19:19
    BSzili
    Posts: 570 from 2012/6/8
    pegasos-sigi2 wrote:
    FreeBasic is slow.
    Good thing it's not available on MorphOS then :-)
  • »21.11.15 - 08:51
    Cego
    so its impossible to port it?
  • »21.11.15 - 09:20
    BSzili
    Of course not. You can port FreeBasic, or rewrite the utility in C.
  • »21.11.15 - 09:21
    marcian0
    Posts: 6 from 2015/11/21
    But what should be the intention of the port? Afaik the Videos are coded for HAM6/8 Playback. What can MorphOS do with that on a ppc environment base? Or is the question about a port to MorphOS for Classic Amigas?
  • »21.11.15 - 09:51
    Cego
    no it's about the video Converter not the player itself. so far you have to use windows or linux to do that.
  • »21.11.15 - 10:10
    marcian0
    Got that wrong!
    Reading really helps sometimes :(
  • »21.11.15 - 10:11
    Cego
    could somebody help out with this? dont wanna install a windows pc just for that :-/
  • »29.03.16 - 21:27
    connor
    Posts: 650 from 2007/7/29
    FreeBasic is slow.
    SDL is slow. Cairo is slow. JavaScript is slow. Hollywood is slow. Now you.
  • »31.03.16 - 17:12
