How to speed up scroll up/down with MUI's scrollbar buttons?
    emeck
    Posts: 175 from 2014/7/15
    Hello,
    is there an option somewhere? Scrolling up/down with the buttons on the scrollbar is painfully slow. Not problem a problem with a normal mouse but if I forgot to carry it, using the powerbook's pad is, well, slow.
    PowerBook 5.8 MorphOS 3.18
    Mac Mini MorphOS 3.18
  • »26.03.16 - 17:52
    Intuition
    Posts: 1113 from 2013/5/24
    emeck wrote:
    Hello,
    Two-fingered scroll mate. :)
  • »26.03.16 - 18:48
    emeck
    That doesn't work with Powerbook 5,2 models :(
  • »26.03.16 - 21:31
    Nadir
    Posts: 176 from 2003/3/17
    emeck wrote:
    Hello,
    There's an ugly way of doing that, namely increasing the frequency of intuiticks. Back in the days of MorphOS on pup hardware I used to do that with a simple command line tool that I had written. While this worked to speed up scrolling in the browsers of the time, it's really a hack which isn't recommended as some software might depend on those ticks arriving about 10 times per second.
  • »27.03.16 - 16:54
    Posts: 1520 from 2003/2/24
    MUI scroll buttons probably should be adjusted to scroll faster. It is ridiculously slow but I admit I never noticed that since I never used those buttons... I am always dragging the bar.
  • »27.03.16 - 17:57
    emeck
    Nadir wrote:
    emeck wrote:
    Hello,
    Not really capable of doing that myself, I think. Anyway, arrow up/down keys work fast so I can live with that.
  • »29.03.16 - 17:53
    emeck
    I'm using the arrow uo/down keys, wich work fast. But sometimes I forget and use the scrollbar buttons!
  • »29.03.16 - 17:55
