E-UAE Documentation, installation, what to put where, config
    Elowan
    Posts: 214 from 2011/4/18
    hi,
    I just downloaded and installed E-UAE (via Grunch) and want to use my already exsisting configs and "hard-drive-folders" with it - but how?
    Maybe I´ve overlook some ReadMe or things like this?
    Where to put the ROM file(s)?
    Where to put the config.txt ?
    Is E-UAE "config-file-compatible" with FS-UAE or WinUAE?
    Basically, I want to use my OS3.9 windows FS-UAE setup within MOS...
    Cheers!
    [ Editiert durch Elowan 10.03.2016 - 09:26 ]
    12" ibook G4 1.33Ghz, 1.5GB RAM, ATI 9550 32MB, 16GB SSD, WiFi, BT, ComboDrive
  • »10.03.16 - 06:25
    beworld
    Posts: 673 from 2010/2/10
    check this : http://www.meta-morphos.org/download/tutorial/E-UAE%20installation%20on%20MorphOS.pdf
    My MOS ports
  • »10.03.16 - 17:49
    Elowan
    Ok thanks for the link!
    I saw, this was for MOS 1.3 - does everything still apply to newer versions of MOS and eUAE?
    Does E-UAE-JIT work now with WHD load?
    kind regards
  • »14.03.16 - 05:40
    Posts: 2217 from 2003/2/24
    Document's version is 1.3, not related to any MorphOS version. It seems to be pretty new, because it talks about G5 support and dates in the first picture are from 2014.
  • »14.03.16 - 07:14
