How to change filemanager background
    Elowan
    Posts: 214 from 2011/4/18
    hello,
    I try to set another color for the filemanager and was looking at the Ambient MUI settings for windows.
    But this seems not to effect the windows of the fliemanager/filebrowser, I believe?
    They are just light blue, like on install - but I turned them to kind of white, like on amiga OS 4.1
    Any way to change the color of this windows?
    Cheers!
    12" ibook G4 1.33Ghz, 1.5GB RAM, ATI 9550 32MB, 16GB SSD, WiFi, BT, ComboDrive
  • »10.03.16 - 16:29
    Posts: 1362 from 2004/2/8
    Settings/Ambient/Background/Window/
  • »10.03.16 - 20:50
    Elowan
    thanks a lot, it worked!
    Got confused with ambient mui window settings.
  • »14.03.16 - 05:34
    r-tea
    Posts: 317 from 2005/3/27
    Note, that there are two display modes in Ambient's filebrowsing windows: icon and list. The settings koszer have pointed to apply to the first one.
    If you want to have the same background picture in the list mode, then you need to open from Ambient's top bar: Settings -> Ambient MUI ... and then select Lists.
  • »14.03.16 - 06:28
