Posts: 159 from 2003/10/24
iirc the HW clock and the System clock are completely different parts. Therefore they can have different times. This allows for a hw clock to be set in (just an example) gmt and your system clock to be set to local time. If you have the right command in your start up they should syncronize on a reboot.
--Mithalas
