Split files with LHA?
    Yasu
    Posts: 1724 from 2012/3/22
    Is there a way to make LHA to split up files when packing, so that it becomes a bunch of LHA files that later can be reassembled easily? I want to pack my sys: and work: drawers for a backup, but since they are bigger than 4 GB I can't put it in the FAT32 usb harddrive in one piece as planned.
    RAR has a way of doing this, but splitted files are not supported by MorphOS it seems.
    Or is there a good, third party software that does the same?
    My MorphOS blog
  • »29.12.15 - 12:41
    connor
    Posts: 650 from 2007/7/29
    lha -V?
    or use Diavolo Backup and set the size of files.
  • »29.12.15 - 12:47
    SKOLMAN_MWS
    Posts: 107 from 2006/10/24
    http://www.onyxsoft.se/joinsplitter.html
    _
  • »29.12.15 - 14:12
    connor
    joinsplitter is a splitter but not an archiving tool. It does not create an lha archive.
  • »29.12.15 - 14:23
    SKOLMAN_MWS
    because first must create archive of files.
    _
  • »29.12.15 - 15:04
    Piru
    Posts: 622 from 2003/2/24
    Split LhA archives should work with MorphOS LhA.
    Note that if the split size is manually specified for LhA 2.7.12, it should be no larger than 2GB (-V2097151).
    I'll fix this limitation for the next MorphOS release.
    [ Edited by Piru 30.12.2015 - 14:07 ]
  • »29.12.15 - 23:53
    Posts: 2732 from 2003/2/24
    It's rapid responses like this that I love about MorphOS and the MorphOS team!
  • »30.12.15 - 09:47
