picasso96 in euae
    amiga4001
    Posts: 454 from 2006/11/16
    I installed the fab version of euae onto a Pbook 5,4 with mos which should support picasso96.
    Installed picasso96 from aminet which I set to uaegfx card.
    But gives me error on picasso96 and no new screenmodes.
    What is going wrong?
  • »21.11.15 - 05:40
    Posts: 12572 from 2003/5/22
    You need SDL-based E-UAE. Which archive have you installed?
  • »21.11.15 - 10:50
    amiga4001
    It's version 0.8.28 which has a sdl version in the archive and a non sdl.
    Sdl version should support picasso96.
    On startup of workbench it comments can't create context for graphic board.
  • »21.11.15 - 13:29
    > It's version 0.8.28
    That's a decade old. Why not use the current version with JIT?
    http://fabportnawak.free.fr/uae/E-UAE_1.0.0-JIT.lha
    Have you assigned any RTG memory in E-UAE config?
  • »21.11.15 - 15:52
    amiga4001
    Thanks for the link I'll try the new version.
    I got it going with your advise regarding the rtg memory.
  • »21.11.15 - 19:15
    cha05e90
    Posts: 58 from 2010/6/23
    ...I'm not sure: but you additionally might use the Picasso96 prefs to attach the emulated RTG board to your UAE monitor file.
    II/G4
  • »25.11.15 - 13:47
    amiga4001
    Ok got it going with picasso96.
    But problems when using rmb menu just freezes.
    So no cleaning up,show all or maybe use keyboard shortcuts?
    Better off with the non sdl version then.
  • »26.11.15 - 05:09
