Advanced Conf Example
    Cool_amigaN
    Posts: 777 from 2011/11/30
    Hi, can someone please provide a sample/example of a fully edited advanced.conf found on prefs/ambient? I 've managed to understand sfx_boot, but what about the others? Which options can be used? On latter stages it would be nice if there was a MUI frontend that would be integrated on the general prefs menu.
  • »11.11.15 - 08:18
    Posts: 12566 from 2003/5/22
    There's an ancient posting on this:
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=4581&forum=9&start=2
    Recent Ambient has probably new ones, and some maybe don't work anymore.
  • »11.11.15 - 08:39
    Cool_amigaN
    Thanks for the reference Andreas. Some options on that old linked thread, now seem integrated on Ambient/MUI prefs system. It would be nice if there was an example for the rest of the config option inside the remaining advanced.conf file though.
  • »12.11.15 - 10:12
    Isn't the documentation contained in the file itself enough?
  • »18.11.15 - 11:39
    sorry, double post
    [ Edited by Andreas_Wolf 18.11.2015 - 14:39 ]
  • »18.11.15 - 11:39
    Tom01
    Posts: 187 from 2009/9/20
    In MOSSYS:Ambient/prefs/Advanced.conf.default you can find the Default-file with Documentation for every Prefs-Entry.
    In SYS:Prefs/Ambient/Advanced.conf you can put the edited Settings.
  • »18.11.15 - 14:17
