Posts: 2728 from 2003/2/24
It could be a master/slave conflict. Set it manually on both the HDD
and CD-ROM (instead of using cable select). If that doesn't work, try
putting both units as masters on their own respective IDE channel.
MorphOS is Amiga
done right!
MorphOS NG will be AROS
done right!
