UAE...booting from directory on hard drive
    TheMagicM
    Posts: 1220 from 2003/6/17
    I forget who it is, but supposedly they had this workin? If so, can you post a command line you used to accomplish this?
  • »10.03.04 - 23:28
    Spidey
    Posts: 568 from 2003/2/24
    Hi TheMagicM,
    Just search old threads concerning UAE.
    I remember questioning this at the time.
    Somebody had a working UAE, but as I recall this didn't work with MOS.
    Bye,
    Spidey
  • »11.03.04 - 10:38
    weiseb
    Posts: 215 from 2003/3/29
    Not realy helping but:
    https://morph.zone/modules/myalbum/photo.php?lid=245
    (but TheMagicM should know about that ; )
    so it is possible.
  • »11.03.04 - 11:30
    TheMagicM
    a hardfile? I thought that was not possible?
    from what luky-amiga is saying, it sounds like he just has a directory with Amiga OS in it.. I've sent him a PM but no replies... and that is why I posted this question because of his reply.
    -Alex
  • »11.03.04 - 12:23
    Doraemon
    Posts: 137 from 2003/7/1
    I was trying to boot from the dev hardfile from: http://www.innoidea.hu/subsites/amiga/developer/phpwebdev.php
    It possible?
    Any idea?
    Thx4all
  • »11.03.04 - 13:19
    Spidey
    Hello luky-amiga,
    I know that command, used it too.
    I did have a partition used for UAE.
    Installed OS3.1 on it.
    But after a softreset in UAE all made dirs (like C and so on) aren't recognised as dirs anymore, but instead they show up as files.
    Also, I couldn't startup from the drive because my used partition wasn't recognised as a harddrive in UAE.
    Which version of UAE are you using?
    Bye,
    Spidey
  • »11.03.04 - 19:18
    Estrayk
    Posts: 142 from 2003/12/30
    Config: PegasosII G4/1000, 256MB DDR400, VooDoo 3000 AGP
  • »11.03.04 - 21:31
