FlashPlayerMOS - who is responsible for it?
    tokai
    Posts: 1289 from 2003/2/25
    i just tested FlashPlayerMOS (download link from morphos-news.de).
    It works so far very well... but there was no readme or anything else inside the archive. Who is responsible for it? :-)
    Some requests and wishes for next version:
    - window should be scalable for non-fixed size flash animations (else it uses the whole screen) or there should be some default size settings or so.
    - external urls should be forwarded to the OpenURL system, so they can be loaded in favourite browser.
    thanks for your attention.... whoever you are. :-)
    regards,
    tokai
  • »10.03.04 - 09:20
  • Visitor
  • @tokai
    just redownload!
    the archive got a readme short after
    release of the downloadlink :)
    Short: MOS version or Flash (SWF) format file player v. 1.0
    Author: Michal 'kiero' Wozniak (Original author: 72207.463@compuserve.com (Mike Steed))
    Uploader: Michal 'kiero' Wozniak (wozniak_m@interia.pl)
    Version: 1.0
    Type: gfx/show
    Requires: MorphOS, Original FlashPlayer
    This is a MorphOS version of FlashPlayer by Mike Steed. For further
    info and usage please download the original archive (gfx/show/FlashPlayer.lha)
    and check included docs.
    // Michal Wozniak
  • »10.03.04 - 09:30
    hooligan
    Posts: 1948 from 2003/2/23
    Suuuure... :-)
    I tried about ten files, two of them ran, both wrong :)
  • »10.03.04 - 10:04
    Sphinx_Ra
    Posts: 276 from 2003/3/14
    Can i use this Program in a Web-Browser ???
  • »10.03.04 - 14:05
    warface
    Posts: 653 from 2003/2/24
    There are some alpha channel problems... For example at the page I've made www.dain.hu the clouds are grayish instead of white...
  • »10.03.04 - 15:45
