mp3 editing
    amiga4001
    Posts: 454 from 2006/11/16
    I want to get me a part off a mp3 song to use as a ringtone on my mobilephone.
    Which program is best for this?
    So loading the mp3 into the program ,selecting a part of it and saving the part as mp3 again.
    Thanks you.
    [ Edited by amiga4001 22.08.2015 - 05:39 ]
  • »21.08.15 - 03:27
    clr666
    Posts: 86 from 2008/7/8
    Some time ago i do same in PSA, and with CLI tool LAME as encoder. But for PSA i suggest read doc first :) Working with this programm is not so obviously.
    _______________
    wintel free
  • »21.08.15 - 03:49
    Krashan
    Posts: 1107 from 2003/6/11
    If you do not need stereo, you can edit audio in DigiBooster 3 too (demo version is enough, sample editor is not limited in any way). However you have to decode your MP3 to WAVE or AIFF with LAME or Zormanita. Then after saving fragment in DigiBooster (as WAVE or AIFF again) you encode it back to MP3 with LAME.
  • »21.08.15 - 03:57
    Posts: 1390 from 2010/1/6
    The best way is HD-Record!
    http://hd-rec.de/HD-Rec/index.php?site=home
  • »21.08.15 - 06:21
    amiga4001
    Ok thanks for the tips.
    Hdrecord is not easy to get going,complains about libs missing..wizard and zlib and camd.lib.
    But also found samplemanager which does what I need.
    Imports .mp3 and can ? save sample as mp3 but that doesn't work for now.
    Complains about stack size of minimum 15000 how can I change that?
  • »22.08.15 - 03:44
    SoundSquare
    Posts: 1214 from 2004/12/1
    an Audacity port would have been amazing but i guess it's way too much work otherwise i guess it would have been done yet
    http://audacityteam.org/
  • »22.08.15 - 09:04
    igracki
    Posts: 471 from 2003/2/24
    I also use SampleManager for this purpose!
    Set the stacksize in the .info file of SampleManager and then start it from WB/Ambient. You can also add it to the MimeType prefs of Ambient to start it with the mp3 file via the contextmenu.
    If you start it from a shell, use "Stack 15000" before starting SampleManager.
  • »22.08.15 - 11:21
    Jambalah
    Posts: 820 from 2008/3/30
    +1
    Pegasos II 1 ghz
    Powermac G5 dual 2.0 ghz
    Powerbook G4 1.67 ghz 17
  • »22.08.15 - 15:56
    +1
    What are you trying to point to?
    The link only provides a "Page Not Found" notice at the website.
  • »22.08.15 - 16:19
    defender
    Posts: 249 from 2011/4/24
    Try the command line tool:
    http://aminet.net/mus/misc/cutmp3-bin-m68k.lha
    copy bin/cutmp3 and bin/sh to sys:c/
    open a shell window to the drawer with your mp3 file and
    type something like this:
    cutmp3 -i Donots_-_Das_Ende_der_Welt_ist_längst_vorbei.mp3 -a 0:37 -b 0:50 -O Ende.mp3
    thats all.
    greets
  • »22.08.15 - 17:14
    Posts: 2732 from 2003/2/24
    Jim wrote:
    +1
    The link has some trailing HTML tags embedded. Either delete these in the URL field at the error page, or simply click the logo image.
    Or click here: http://audacityteam.org/ ;-)
    I love Audacity, I use it a lot!
    If a MorphOS/MUI port could be done by someone, I would be very happy!
  • »22.08.15 - 17:39
    On HD-Rec - homepage are all links for needed 3rd-party software - whats the problem?
  • »22.08.15 - 17:43
    Posts: 12566 from 2003/5/22
    >> +1
    Nothing, I guess. He just wrote "+1" after all :-)
  • »22.08.15 - 21:45
    ...or the original link in posting #6 :-)
  • »22.08.15 - 21:46
    igracki
    thats all.
    greets
    Hi, I made a quick port of version 2.1.1, its about 3 times faster than 68k version!
    Playing seems to not work, I can't hear anything;)
    But cutting works;)
    cutmp3 v2.1.1 MorphOS
    Now I ported current v3.0.1 of cutmp3 and made some changes to be able to play (using c:Play;) the current part of a mp3, when in editing mode!
    Specifying new id3 tags works, but you don't see what you are typing;)
    Grab it here:
    cutmp3 v3.0.1 MorphOS
    Maybe I do a muigui for this...
  • »23.08.15 - 11:39
    defender
    cool a native port of this cutting toy was what I have been looking for.
    I used this tool a lot when i had linux as my main system years ago.
    Gui version would be even better - but the command line is quiet easy
    to handel :-) and its ultra fast as well!
    thx igracki
  • »23.08.15 - 16:20
